Tuesday night meets @ 403 & Dundas
you will keep the warrenty.
you can actually buy stage 2 for alot cheaper then i did, the price went down over there.
some dealers still overprice the kit.
stage 3 consistis of a dual pass endplate, pcm which allows you to adjust rev limit, has a high octane mode, a nitrous mode or the 2.9 pulley mode which coems with the kit, you can also get a bigger second coolant tank and rig up some plumming so you have 2coolant tanks which reduces yer intake temps that much more.
i will probably use the extra tank since it will reduce the engine pulling timing after lots of hard runs.
cool idea like i said just helps with cooling but worth it for people running smaller pullies
Last edited by distillion; Feb 12, 2007 at 11:25 AM. Reason: Automerged Doublepost
Sweet! Thanks a bunch man. What was that piece that some guys had put on to prevent wheel hop; engine dampener or torque dampener or something or the other...do any of you guy have that installed? Or even know what I'm talking about? lol
check out tags website, they have mounts that will keep the engine from rocking violently yet it wont give you harsh vibes like all the solid mounts do due to the type of materialthey use, i belive there are 3 different types, the harder the compound , the less wheel hop but the most vibes, i personally will go with the one with the least vibes but its still doing something since my car is a daily driver.
control arm bushings work well too to prevent wheel hop,.
hey my highway pull friend, honestly me and my buddy, about to leave we see come colbalt SS's. Being GM fans ourselves we cruize by you guys are leaving, so we follow. Neither of us have ever seen a Colbalt go and we wanted. **** MAN they pull HARD. Sorry if i jumped the start, did you hear me bounce off the rev limiter, i didnt think you went then you did, and yeah you started pulling around 210 and then traffic.
SWEET RIDE MAN
SWEET RIDE MAN
2003 G35, stock.
either way, what do these things top out at!
hahahaha i think ill need to bring a differnt car lol.
But i am down.
Last edited by userchemical; Feb 12, 2007 at 12:31 PM. Reason: Automerged Doublepost
Seriously I need summer asap
anyone interested in this
https://www.cobaltss.net/forums//showthread.php?t=46526
Last edited by Toronto SS; Feb 12, 2007 at 12:42 PM. Reason: Automerged Doublepost
If you have it, you don't need it. If you need it you don't have it. If you have it you need more of it. If you have more of it, you don't need less of it. You need it to get it. And you certainly need it to get more of it. But if you don't already have any of it to begin with, you can't get any of it to get started, which means you really have no idea how to get it in the first place. Do you? You can share it, sure. You can even stock pile it if you'd like. But you can't fake it. Wanting it. Needing it. Wishing for it. The point is, if you've never had any of it, ever, people just seem to know.
That's not true my little Calzone eating friend. I have heard many times over that 3rd is closer to 1:1
But case in point, as off as a dyno may be it's best to get it tuned and dyno'd again on the same dyno as the gains will be consistent.
Bring it, I got somethin' else for ya
