Calgary - random talk thread
Kaisobudda says....
[/QUOTE]
Always be a first rate version of your self instead of a second rate version of someone else.
Knowledge talks, wisdom listens.
Not to care for philosophy is to be a true philospher.
He who knows others is wise. He who knows himself is enlightened.
If you are not part of the cure, then you are part of the problem.
The only time you run out of chances is when you stop taking them.
The best things in life are not things.
I don’t know what the key to success is, but the key to failure is trying to please everyone.
[/QUOTE]Always be a first rate version of your self instead of a second rate version of someone else.
Soooo....I have had it with this ******* car. I will never bye GM ever again. I am putting this car up for sale.
I get a call from Jack Carter This morning and they will not warrenty the master cylinder on my car. They caim that the Clutch pressure is the cause for the failure and not the fact that the master cylinder is a cheap peice of plastic ****.
I am so pissed off right now I can't believe it.
Larry
Larry
Good old dealership working at its best to not take the blame.
Thing is though Larry....it does not matter what dealership you buy from, they are all the same. They always find a way to weasel out of an obvious warranty problem.
If I were you, I would take it to another dealership.
Larry
Larry
My strut bar came in, Imma prolly pop her in at lunch.
Larry
Larry
Here is what the damage looks like that they say they wont fix.
You are standing looking at the firewall from the front of the car. The tabs you see are bent. You can also see the small stress fractures on the sides of the tabs in the fire wall. They told me I would have to take the car to a performance shop to have it fixed so that they could welld up a braket or something to make it stronger. They then blamed the clutch pressure for the failure and would not warrenty the work. So I just payed 200 bucks for them to not fix anything and give me some story about how they don't have a tiege (sp) welder blah, blah, blah...
That's why I'm pissed.
to keep things a little cheaper make sure carters doesn't reinstall anything as that will cut down time that our techs will have to be under the hood of your car. and did parts find that bracket you were looking for?
Larry called me today to vent it was funny
In all serious though that's bullshit that they wont warranty it. The exact same thing happened to me and if a STOCK clutch can do that, then it wasnt just because of the "high performance" clutch. It's just weak to begin with. I'd call GM directly and try and plead your case. Maybe they will meet you in the middle or something to try and help you out. Especially when the "GM Certified" technicians didn't know how to fix it
That right there tells me there's something fishy going on. Jack Carter = Garbage. Hopefully **** can help you out...
They have already taken out the fuse box so at least that does not have to be done.
Thanks for letting me vent Rob. It was kind of funny.
No parts did not find the part but I have the number. Part #: 15258000
