Calgary - random talk thread
Anybody have any ideas to which clutch and flywheel I should use? I'll be spinning the motor to around 8K after it's broken in and I swap over to a ported head and turbo cams
found out the torque capacity for the spec stage 2+ sitting in my basement. It's rated for up to 440 ft/lbs, All I would need is a flywheel but I think I might need a bit more holding power
check this out
https://www.cobaltss.net/forums/loun...as-lsj-293787/
if i would have been able to get my car up there already i'd let you feel how the zzp s4 drives. it's definitely a clutch more people need to be using. it's streetability is remarkable for how much it holds.
