Calgary - random talk thread
I'd like to hear a sound clip of his before I'd bother him. I'm still on the fence about dropping the Hahn or the longtube. It's a tough choice! Lol
I do have my hpt. Haven't really found the time to load it up and play with it
I just did a search and found a handful of reasons why you are raspy. None of them require getting rid of the header. We will have to spend some time troubleshooting when you are in town; we'll get it figured out.
Lol oh? If my computer was running properly I could do a search but my phone is all I got right now! I seen that the 3 inch pipe is why it's raspy the sound resonators too much and the airflow is too fast to take the rasp out before it leaves the resonator
Lol the more minds the better
Yeah, I would check on the blue lightning guys exact setup, it would help us immensely in troubleshooting.
And what? Your computer? you got two local it guys on this crew that can fix that **** toot sweet.
I still have it. ( hp tuners)
Meth does nothing to the motor. I sprayed heavy with 100 percent meth for 35000km and nothing was corroded at all. You aren't spraying that much
I was spraying a 9 gph nozzle at end with higher pressure so probably closer to 10-11 and it felt like a nitrous shot when it hit
got some stuff for sale
BNIB Hurst Pistol Grip Quarter Stick Comp Auto Shifter
never used, barely even opened
original Hurst webpage:
PISTOL-GRIP QUARTER STICK
270 obo
BNIB Hurst Aluminum Cover Kit
ALUMINUM COVER KIT
55 OBO
MSD Ignition Control MSD-6AL pt#6420
BNIB, never used
Digital 6AL Ignition Control - 6425
200 obo
Comp Cam 23-000-9 Camshaft
COMP Cams 23-000-9 - COMP Cams Custom Ground Camshaft Cores - Overview - SummitRacing.com
300 obo
270 obo
ALUMINUM COVER KIT
55 OBO
BNIB, never used
200 obo
300 obo
HERE is his original thread when he was trying to find a solution...
Then HERE is his thread after he found a setup he liked...
Like mentioned in that second thread, four bangers are always going to be a compromise of some sort... which is why I just roll with it and call the GA plain old noisy.
A lot of the reading I did pointed to either poor seals on the gaskets or engine movement as the cause of rasp. I think having the exhaust fully welded from end to end and installing solid mounts would help...
Here's the highlights from the second thread I linked;
at least my memory still works
From our conversation, and some of what you've said here I think this video should pretty much confirm that you should be able to find a nice compromise and keep that cool header...
it's kinda weird - seeing two videos of his car in the light... I've only ever seen it at night
Here's a quick in cab video i did with my iphone
YouTube - ‪Cobalt SS/SC With Walker Quiet Flow Muffler In Cab‬‏
Ya. I had a band clamp on the 3 inch 2 bolt adapter but the exhaust shoot welded the flange to the resonator. I guess the joints could be causing rasp. I do have the issue of the exhaust hitting the car when I downshift from second to first if I don't do a slow transition! Lol
