oil change monitor
Old Jul 23, 2009 | 12:40 PM
nickmacgregor's Avatar
oil change monitor
Is there any way to reset the oil life monitor on our cars? My dealership in town recently got shut down and I dont want to take it to the other dealer. Im suspecting it might have to be hooked up to a scanner but thought I would check
Old Jul 23, 2009 | 12:42 PM
silver187666's Avatar
as in put it to 100% check your manual
Old Jul 23, 2009 | 12:44 PM
pykie's Avatar
turn the key to the on position, press and hold the 2 button you use to scan thru the menu on your cluster and push the gas pedel 3 times
Old Aug 2, 2009 | 02:15 PM
mkriebs's Avatar
You don't need to push the gas pedal.
Old Aug 2, 2009 | 02:24 PM
Snakes709's Avatar
scroll to your oil life....press and hold the reset button and the info scroll button (whatever its called) hold it for a few seconds....menu will come up...scroll to oil life...press reset and it will go back to 100%. While your in the menu set up u can mess around with other stuff...ie, change it to mpg or L/100km or w/e u want...i spent a about 30mins just messing around with stuff
Old Aug 2, 2009 | 02:26 PM
bryce712's Avatar
key to on position gas pedal 3 to 5 times done
Old Aug 3, 2009 | 08:42 PM
rhynoj's Avatar
dah mcgoog!
Old Aug 3, 2009 | 08:44 PM
outtamymind's Avatar
its only 3 times
Old Apr 19, 2010 | 08:41 PM
Jeffs 06SS 2.4's Avatar
Just did the "turn on key, go to oil life and hold the button and hit the pedal 3 times and it worked" Thanks!!! I thought someone was kidding. Thats a weird way for a big company like gm to do something. Oh well, it worked.
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
roth
Sep 26, 2015 12:16 PM
