94 Jeep Wrangler springover and 8.8 rear on 33's
Up for sale is my 94 YJ. I recently put a lot of work into it and decided I really don't have the time to use it other than a daily driver. YJ has the I-6 with 5 speed behind it, NP231 with SYE kit and Tom Woods drive shaft. At the back of the Jeep has a Ford Explorer 8.8 with disc brakes, 4.10 gears and factory limited slip. The wheels and tires have less than 5K miles and have no wheeling trips on them. Up front has an older XJ high pinion Dana 30 with 4.10's and a lockright locker. Will throw in the stock axles with the deal. As the title says it has a spring over conversion using newer factory springs, brand new shocks all around and has a 1" body lift. As you can see in the pics the YJ has the hardtop and full hard doors, plus a bikini top for the summer and a KC lightbar that isn't installed. I also have heavy duty steering setup but knuckles need drilled. I'm sure there are some things I'm forgetting so please let me know if you have any questions or need pictures of anything else.
5700 OBO
5700 OBO
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
