Drag Racing Kindle Racing and Dalcorp Racing
06 balt 1/4mile
Old Apr 16, 2012 | 10:59 AM
ill-SS.'s Avatar
06 balt 1/4mile
so finally took my 06 supercharged cobalt to the track has a cold air intake. best time of 14.8 with a reaction time of .74. 60ft of 2.3.mph of 94.3 didnt touch the tire psi or any thing just wanted to put a time on the car any tips to get to my goal of flat 14s?thanks
Old Apr 16, 2012 | 11:05 AM
jmfselu's Avatar
practice practice practice. a tune would help drastically, or a stage kit. Some mounts (motor, tranny) would help for launching. Maybe deflate the tires a tad bit when you get out there.
Old Apr 16, 2012 | 02:03 PM
ill-SS.'s Avatar
yea had a total of 8 passes i was thinking of doing a zzp stage 3 kit also a full exhast. maybe some better tires for the front. thanks
Old Apr 16, 2012 | 02:34 PM
nizzle's Avatar
I got a 14.5 outta mine stock. To get to a 14.0 I 'd say zzp stage 3, TTR upper mount, powell stage 1 rotated mounts, and lower it. With that and a good launch, you should be in the high 13's somewhere IF you clutch holds
Old Apr 18, 2012 | 09:29 AM
ill-SS.'s Avatar
not bad ill lookin to getting the zzp stage 3. do you think the clutch wont hold up???????
Old Apr 18, 2012 | 09:34 AM
robd53's Avatar
If the clutch is stock... it doesn't like when there's more power and more abuse - especially at the same time.
Old Apr 19, 2012 | 12:28 PM
ill-SS.'s Avatar
whats a good clutch to go with? plus i sum times let my girl try to drive it lol.
Old Apr 19, 2012 | 12:31 PM
SlowCobaltSS's Avatar
Not bad for the first time at the track with the car
Old Apr 19, 2012 | 12:36 PM
ill-SS.'s Avatar
thanks that was actually my first pass then it was all low 15s the rest of the night for me lol.
Old Apr 19, 2012 | 12:43 PM
InfraRedline's Avatar
Not bad. Thats the same time I did stock, except your trap seems low. I trapped 99.7 stock, with the lowest of the day being 96.9 IIRC.
Old Apr 19, 2012 | 01:05 PM
nizzle's Avatar
stock LSJ clutch blows chunks get the gmpp LSJ clutch upgrade..... Under $300 from CED iirc
Old Apr 19, 2012 | 01:14 PM
Staged07SS's Avatar
Administrator
Administrator
With ZZP S3 power levels the stock clutch will be fine....
The stock clutch is not as bad as everyone makes it out to be.
If your clutch is old, and you sense it is sliping, then by all means swap it out with something along the lines of the gmpp clutch.
Old Apr 19, 2012 | 03:07 PM
MyOtherSS's Avatar
Those are some good times for the first time at the track with only an intake. I don't understand why people say the stock clutch is that bad, my cars got enough power to run mid 13's and it's fine with 53k.
Old Apr 19, 2012 | 04:51 PM
nizzle's Avatar
My stock clutch started slipping around 40k or so, even before I had mods. Got worse and worse once I started modding. Might just be me (rough on clutches) but I put in the gmpp LSJ clutch upgrade and NEVER had any problems with it again.
Old Apr 19, 2012 | 05:34 PM
Were you getting any tire spin?
Old Apr 20, 2012 | 02:53 PM
ill-SS.'s Avatar
yep not somuch on my best pass but that was thye problem of the night. im at 58k miles. clutch is strong.
Old Apr 21, 2012 | 03:28 PM
DarkChild's Avatar
One tip that really helps. There are many threads on this. Ride the clutch on the launch. It works great.
06MetallicBalt
Jul 20, 2025 08:47 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dasoftest
Sep 29, 2015 02:14 PM
roth
Sep 26, 2015 12:16 PM
Cptnslo
Sep 24, 2015 09:32 AM
