Drag Racing Kindle Racing and Dalcorp Racing
Fastest 2.4L?!?!?!
Old Oct 15, 2008 | 09:37 AM
  #51
Dunkinuts's Avatar
Originally Posted by Projekt
1500-2000
depending on how well the track is holding the power, try launching closer to 2500
Originally Posted by REDFOCZ
No love for the Ion, guess you wont post my time
I am not making a list I just copied from the official 1/4 mile thread for ref.
Originally Posted by elecblue06
well i should be one of the fastest by the end of today... should be.. you never know with me lol
good luck, any times as of yet?
Old Oct 16, 2008 | 10:16 AM
  #52
elecblue06's Avatar
no times as of yet.. and i was one of the fastest 2.4's for about an hour
http://s200.photobucket.com/albums/a...t=MVI_1474.flv
http://s200.photobucket.com/albums/a...t=MVI_1475.flv
and i was definitely faster... it took 2500 rpms to get 10 mph where as before it took 3000 rpms lol but it was weird... it felt like i was NA then again i didn't stomp on it so i dunno how the higher rpms felt
Old Oct 16, 2008 | 10:34 AM
  #53
Dunkinuts's Avatar
not bad but haveing that half of a snail there takes you out of my category. but killer set up.
Old Oct 16, 2008 | 10:36 AM
  #54
INDColtsFan18's Avatar
I'd love to hit 14's with my 2.4 N/A.
Old Oct 16, 2008 | 03:51 PM
  #55
redssna's Avatar
I wish mine was faster. I know that I can get a better run out of it I just need to get my 60' down a little better. can wait for next spring and a 75 shot. It's killing me just having everything sitting in my apartment.
Old Oct 16, 2008 | 04:36 PM
  #56
Dunkinuts's Avatar
haha I agree. I am prob. going to end up with spray. I want to try and get near 13s without it first. I have exhaust, header, tires, and tune to do before I put on the spray.
Old Oct 16, 2008 | 08:48 PM
  #57
NotME's Avatar
wow, good times man...i gotta hit up the track with you before they close this year.
Old Oct 16, 2008 | 08:51 PM
  #58
LS6Rally's Avatar
i hot 15.3 with an SRI 14's bolted should be no problem
Old Oct 17, 2008 | 09:29 AM
  #59
Dunkinuts's Avatar
thanks man, you better get to the track soon! we only have about 2-3 weeks left.
yeah def. work on that launch. I was at 15.3s at the beginning of the summer.
Old Oct 17, 2008 | 09:51 AM
  #60
LS6Rally's Avatar
yea i know my 60 ft sucked. 2.33 i know i can do better. im not satisfied witht the bridgestones. i think they're to hard of a compound to stick they just wanna spin.
Old Oct 17, 2008 | 09:56 AM
  #61
brickerenator's Avatar
mebbe if they were warmer?
Old Oct 17, 2008 | 10:03 AM
  #62
LS6Rally's Avatar
maybe, but im not going throught the water box, it wont make it anybetter. i was runnning at 22 psi. i didnt wanna go much lower. well see ill go back next year.
Old Oct 17, 2008 | 11:00 AM
  #63
Dunkinuts's Avatar
yeah 22psi is pretty low for a street tire. I just keep mine in the low 30s I don't change things around, just in case i forget to change them back. But I am also looking at getting stickier tires for the spring.
Old Oct 17, 2008 | 11:05 AM
  #64
Brandon97Z's Avatar
22 is way to low. Stick with the upper 20's low 30s. I usually run about 28lbs in the front depends on the weather/track conditions. I'll start at about 35 or so and start working my way down as the night goes on depending on what hooks and what doesn't.
Old Oct 17, 2008 | 11:10 AM
  #65
Viper33884's Avatar
I would add my time but the only time's I have is from the 1/8th so far but I think next month were hitting up the 1/4.
Old Oct 17, 2008 | 11:13 AM
  #66
Brandon97Z's Avatar
1/8th miles are welcome. There's one 20 min from my house and is what i most frequent. Closest 1/4track that is actually worth to run on is 3 hrs. Went to IRP in indy and it was hoorible. .5 sec slower 1/8th mile times 2-3mph slower........ could only muster a 15.3 @ 92ish.
edit:Never mind checked my slips
IRP times
60 2.39
330 6.59
1/8 10.00 72 mph
1000 12.92
1/4 15.39 91mph
local 1/8th mile
60 2.28
330 6.34
1/8 9.66 74mph
Old Oct 17, 2008 | 11:38 AM
  #67
Viper33884's Avatar
Best I ran right before we left it was about 75deg. and track prep was decent but mine wasn't. I left the 38lbs in the tires.... Next time I will be more prepared.
0.058 - Reaction
2.403 - 60'
10.096 - 660~1/8th
73.43
I need a tune so bad...down low is killing me, and my launches were decent, had a few wheel spin problems but I worked around it. Maybe next time I go I will have a tune.
Old Oct 17, 2008 | 11:42 AM
  #68
Dunkinuts's Avatar
0.058 - Reaction
2.403 - 60'
10.096 - 660~1/8th
73.43
yeah you 60' is pretty slow, nice reaction though. What are you laucning at? try lowing the PSI to 33 or so.
Old Oct 17, 2008 | 12:28 PM
  #69
Viper33884's Avatar
Thanks, and around 2300 mines auto so break/gas and I will next time for sure.
Old Oct 18, 2008 | 12:09 PM
  #70
BigEMU1's Avatar
Is it possible there's a tune discrepancy or some other factor that's allowing the 08's to run such lower times relatively stock? I'm a 07 fully bolted (I/H/DP/E) and the best I could pull was:
Left lane
Now granted I'm completely untuned so I would obviously get a lot considering the stock tune is crap plus all the added mods. I don't have anything else like suspension, mounts, or tires, but I did remove my spare tire in the back. Not really interested in removing interior seats to lower my times.
I saw that some people are hitting 2.2's in their 60'. I consider myself a pretty good driver but I'll admit the track conditions weren't the greatest, motor was running a little hot. How can I get my times down other than with mods. I'm thinking I need to get my launch down better, I normally run on the street where I'm a much better driver. It's easier to just dump the clutch and throttle the gas... at the track is tough because I have to rev HIGH HIGH HIGH and feather the clutch otherwise it either bogs because its really sticky or I hop.
Suggestions?
Old Oct 18, 2008 | 12:14 PM
  #71
Viper33884's Avatar
Work on your reaction for one. Good time non the less. I have to work on my track prep next time. And get some suspension mods, or just put some mini footballs inside your rear springs to stiffin up the rear end. I think it was posted here or somewhere else. I will try to find it.
Hatrickstu Mod:
Next time I go I might try this.
Last edited by Viper33884; Oct 18, 2008 at 12:14 PM. Reason: Automerged Doublepost
Old Oct 18, 2008 | 12:25 PM
  #72
iLLmaTic3s's Avatar
interesting
Old Oct 18, 2008 | 12:28 PM
  #73
Viper33884's Avatar
Originally Posted by iLLmaTic3s
interesting
Stu said it works awesome...plus it's cheap and easily removed/installed. Props from me, if I get my tune and slicks next Thursday I will hit the track up again and see the difference.
Old Oct 18, 2008 | 12:42 PM
  #74
iLLmaTic3s's Avatar
a good auto tune opens the car up real nice btw. ive had my car tuned since may 07...still runs strong..havent been to the track since stock no have full bolt ons and tune
Old Oct 18, 2008 | 12:46 PM
  #75
Viper33884's Avatar
That's the main thing with me, I'm trying to talk between RedFOCZ (Mike) and Ecotecon18s (Terry) so Mike can send Terry a tune and it will me a lot easier to tune me since Terry is closer lol.
I'm really looking forward to is either this Thursday it will be tuned or next weekend. Then track time to compare, plus I'll have drag radials on top of that.
