Drag Racing Kindle Racing and Dalcorp Racing
going for 11's on friday
Old 05-11-2012, 07:31 PM
  #76
Edubs's Avatar
Good Luck!
Old 05-11-2012, 10:38 PM
  #77
zrated89's Avatar
Motors done guys it was a good run. Will update later sounds like a ringland wrx exhaust
Old 05-11-2012, 10:46 PM
  #78
yellow dragon's Avatar
Ah **** what was ur best tonight?
Old 05-11-2012, 10:59 PM
  #79
zrated89's Avatar
Best remains 12.0@117
Old 05-12-2012, 01:14 AM
  #80
thedubsack85's Avatar
Did it let go on a run? Do a compression check ASAP!
Old 05-12-2012, 01:42 AM
  #81
Got Bewst?
Bluelightning's Avatar
Damn! That's just too bad
Old 05-12-2012, 02:27 AM
  #82
zrated89's Avatar
still runs and drive gaurantee its a ring land will check into it tomorrow i knew it would happen sooner or later 80k hard miles hundreds of track passes i have the parts to rebuild her so shell be back on the road in no time
Old 05-12-2012, 03:52 AM
  #83
USA Y U NO HAVE AUTOBAHN?
tylerjclance's Avatar
awwhh wtff :-/
that's too bad man
Old 05-12-2012, 08:27 AM
  #84
freakta's Avatar
too bad. but you will come back stronger
Old 05-12-2012, 10:10 AM
  #85
zrated89's Avatar
yea man. I anticipated it as hard as i push her. was hoping to see that 11 though before she gave. gonna tear her apart today
Old 05-12-2012, 02:38 PM
  #86
zrated89's Avatar
confirmed. compression on 1, 2, and 3 were 225-230. Cylinder 4 is 130. Time for the build to commence
Old 05-12-2012, 02:46 PM
  #87
Well atleast you were prepared for it to go! And pretty much ready by the sound of it! Good luck cant wait to see some big numbers once built!
Old 05-12-2012, 02:50 PM
  #88
zrated89's Avatar
i knew it was coming i got greedy trying everything to run the 11, and pushed the blower and the car pretty hard. Its all good though i have most everything now for a pretty sick setup
Old 05-12-2012, 04:38 PM
  #89
Perfect.disguise's Avatar
Going to keep the SC or ditch it?
Old 05-12-2012, 04:51 PM
  #90
100% METH's Avatar
Blower!!!!!!!!!!!!!!!!!!!
Old 05-12-2012, 04:55 PM
  #91
I say ditch it and aim for 10's instead of 11's.
Old 05-12-2012, 06:20 PM
  #92
zrated89's Avatar
going to a 10.1 comp piston with total seal rings. All of my valvetrain components to run a 9k rev limit is already here. Head is being ported, going to pulley up with the comp to keep blower and iat temps happy. should go mid 11s all day like that and then maybe a shot to put her into the tens.
Old 05-12-2012, 06:25 PM
  #93
carstedt's Avatar
wut rpm do ur cams make peak power at?
Old 05-12-2012, 08:35 PM
  #94
zrated89's Avatar
basically the same as the zzp stage two cams only a little more aggressive lift
Old 05-13-2012, 02:21 PM
  #95
freakta's Avatar
i really cant wait to see what it does
Old 05-13-2012, 10:08 PM
  #96
zrated89's Avatar
number four got rick rolled amazingly sleeve isnt even scratched. i almost didnt see it the piston ring kept her in tact. On i removed the rings she fell apart lol. Light honing with a 240 grit ball and the diamond 10.1s are going in with total seal rings . Head is already being prepped for valvetrain
Old 05-14-2012, 12:20 AM
  #97
Got Bewst?
It's been done. What hasn't been done is going 11's with a blower.
Old 05-14-2012, 07:19 AM
  #98
Administrator
Administrator
Staged07SS's Avatar
This....
Everyone is so fast to give up on a blower car. This blower car is faster than 90% of the turbo cars on this site, haha.
zrated: I give you props for how hard you push your car, and how close you came to your goal. Good luck with your build man!
Old 05-14-2012, 07:32 AM
  #99
zrated89's Avatar
thanks buddy the sad thing is that if that stupid reducer gromet for my mechanical autometer gauge didnt blow off cuasing my meth not to kick on going down the track, then this would have never happened. i really know i could have went 11's on stock internals and thats what i wanted to do. Hell i even thought about throwing a stock single piston in and doing it to prove a point, but no sense since im already in there
Old 05-14-2012, 07:35 AM
  #100
Oh man, I'm going to the track this weekend with my tvs.
I'll be happy with a 12.9 hahaha
Quick Reply: going for 11's on friday
