Drag Racing Kindle Racing and Dalcorp Racing
My First Track Night
Old Aug 16, 2007 | 09:52 PM
Yellow Submarine's Avatar
Ran for the first time at No Problem Raceway last night. Thought I would be faster, but the ridiculous heat and humidity may have something to do with it.
1st run : 16.48 @ 81.09
2nd run : 16:60 @ 80.53
3rd run : 16.37 @ 83.66
Is this normal for the 2.4 automatic?
Old Aug 16, 2007 | 09:54 PM
BriantheLion26's Avatar
Well the heat never helps. I thought they ran about 15.5ish. What were your 60' times?
Old Aug 16, 2007 | 09:59 PM
g5mike's Avatar
Heat is a definite killer,a friend ran my car last week in 100degree weather and only got a 15.1
Old Aug 16, 2007 | 10:06 PM
60 ft
Hehe, forgot the 60 fts. 1st: 2.467. 2nd: 2.490 3rd: 2.497
I'm not even going to post my reaction times...
I still managed to beat a CRX and a Ram Big Horn truck
Last edited by Yellow Submarine; Aug 16, 2007 at 10:07 PM. Reason: Automerged Doublepost
Old Aug 16, 2007 | 10:08 PM
Well that is your main problem right there. Get that to a 2.2 and you will see 15s easily. How did you launch? Autos should be pretty easy to launch, just brake torque it. Right before the light goes green (or before you want to launch, R/T doesn't mean anything on normal ETs) just hold the brake and floor it, then release the brake and hold on!
Like I said, R/T doesn't matter. If you are bracket racing it does, thats it. Mine were like .5-.7 when I went lol.
Last edited by BriantheLion26; Aug 16, 2007 at 10:08 PM. Reason: Automerged Doublepost
Rangerondubz's Avatar
Gotta def work on your launches!
Old Aug 16, 2007 | 10:09 PM
i brake torqued it in L the first time and spun my ass off. Second time tried with it in drive and I could feel that it was slower. Third run I did a little burnout and took off in L again.
Old Aug 16, 2007 | 10:18 PM
Jimmys2007CobaltSS/C's Avatar
are u stock...? if so u should be at 15.8-16.0
Old Aug 16, 2007 | 10:24 PM
madeinUSA's Avatar
Heat is a time killer. Work on different launch techniques. Also your mph on last run was 3 mph higher than second= that is a big difference. Make sure you are running wide open way past the finish line...seen so many people let off right before reaching the finish line @ the track I go to which kills mph.
Old Aug 16, 2007 | 10:42 PM
I am stock except for GM touring exhaust. I think I may have let off early my first run. Also, I didn't realize it would shift into second in "L". I was shifting into "I" or 2 to hit second gear, which may have messed up my shift points or something. Still learning how to play with her
Sl0wbaltSS
Nov 21, 2018 11:11 PM
n20saturn
Drag Racing
19
Oct 6, 2015 12:38 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Extremespeed
Sep 29, 2015 04:34 AM
