Drag Racing Kindle Racing and Dalcorp Racing
Tell us how you launch with slicks. & 60 Foot Times
Old Sep 14, 2009 | 12:56 PM
mongorat427's Avatar
Smile Tell us how you launch with slicks. & 60 Foot Times
Trying to see who has the best technique for launching with slicks and Dot radial drag tires. Give us your launch RPM, 60 ft times. and ET Top speed.
Old Sep 16, 2009 | 11:10 PM
Matt M's Avatar
With slicks- 6500 RPM, clutch fully engaged by ~10 feet out. 1.73 sixty foot.
Old Sep 16, 2009 | 11:13 PM
BLAZIN07SS's Avatar
I'm too JDM for you
with DR's. 3800rpm, slightly slipping the clutch out of the hole. 1.92 60 foot
Old Sep 17, 2009 | 12:19 PM
cmiller8006's Avatar
Slicks 4500 dump the clutch(stock clutch by the way), 1.89 60 with a 12.2 at 112.xx
Old Sep 17, 2009 | 05:08 PM
Smile
Sounds good what kind of wheels and slicks are you running ?
How far does the rpm drop once your fully hooked up ?
Your car is built almost exactly like mine. 09 SS TC Yellow Aem intake, Dejon Cp, Hahn Catted Downpipe , Jennetty 3 inch exhaust, Hurst short throw, Engalls Stiffy, Ott Mounts , Trifecta Dual Tune
Last edited by mongorat427; Sep 17, 2009 at 05:16 PM. Reason: Automerged Doublepost
Old Sep 17, 2009 | 07:36 PM
Matt M's Avatar
Centerline Storms, Mickey Thompson ET drags.
I don't remember exactly, but I think it drops to around 4500-5000 RPM.
Old Sep 18, 2009 | 07:14 PM
XM15's Avatar
Sub'd.
I really want to cut off one more tenth before I boost it.
Old Sep 27, 2010 | 04:53 PM
1SLOLT1's Avatar
Is that with brembos still installed?
Old Sep 27, 2010 | 05:09 PM
No..
Old Sep 27, 2010 | 05:20 PM
crazywhiteboy89's Avatar
sub so what the best rpm on a lsj lol
Old Sep 27, 2010 | 10:16 PM
beast10007's Avatar
1.85 60ft
It was around 5,000rpm
yes stock brembos
Old Sep 27, 2010 | 10:21 PM
Matt M's Avatar
No..
Correct. No LNF Brembos.
Old Sep 27, 2010 | 10:50 PM
beast10007's Avatar
****I was on the bick slick 17" rim
Old Sep 28, 2010 | 05:52 PM
skip_jones's Avatar
hey mongo what is your best 60 so far on the DR's??
Old Mar 17, 2011 | 12:08 AM
06'Yellow SS/SC's Avatar
I'm in for the same info
Old Mar 17, 2011 | 12:14 AM
thebucky84's Avatar
x2 ^^
Old Mar 17, 2011 | 12:18 AM
redcobalt07's Avatar
What do you think the risk of snapping the axles are on 2.2 cobalts?
Old Mar 17, 2011 | 12:23 AM
There is no best rpm. It depends on the cars setup, tune, track, tire, weather, alot of things. You just have to practice with different styles and techniques till you get it figured out. You can't even stay at the same rpm run to run or day to day, things will always be changing minute to minute. There's been times I have had to lower tire pressure in the staging lanes because someone broke down. Usually after that the track won't hook as good for a bit till it gets more rubber down, unless they spray vht, then your good.
Old Mar 17, 2011 | 08:52 AM
Ryan@zzp's Avatar
Slicks, 5500-6500 depending on track, slip the clutch just until the cars starts to roll, then full engagement. Best 60ft no wheelie bar 1.68, best with 1.59
Old Mar 17, 2011 | 09:15 AM
Kildore's Avatar
Bumb for later : )
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
