Drag Racing Kindle Racing and Dalcorp Racing
tips?
Old Sep 6, 2011 | 02:27 AM
damastah's Avatar
tips?
going to the track first time friday... i really dont want to **** any **** up... got stock contis on... still waaay above wear indicator...
i got full 3" exhaust catless dp and back to a 3.5" tip. injen cai, and trifecta tuned at 21 psi...
what sort of ETs do you think i will be running?
also, what can i do to help launch the car fast to try to get a 2.1 or better 60'.
and finally, how should i shift? im not using NLS.
Old Sep 6, 2011 | 02:28 AM
cmatthewb101's Avatar
You should shift from 1st to 2nd, then to 3rd, and then 4th if needed. Best of luck!
Old Sep 6, 2011 | 02:29 AM
HB_SS/TC's Avatar
gas out
clutch in
go to next higher gear
clutch out
mash gas
Old Sep 6, 2011 | 02:55 AM
FrossB's Avatar
Thread Killer
Good ol' late night advice hahaha
Old Sep 6, 2011 | 03:02 AM
damastah's Avatar
this is ******* bullshit...hahahahahahahahahaha
Old Sep 6, 2011 | 03:12 AM
FrossB's Avatar
Thread Killer
but uhh..never been to the track myself (going to Bandimere ont he 16th to take some runs) but just going from other threads that ppl have put...
avoid water box..spin the tires to clean them..hold at designated rpm (no clue what rpm exactly..3000ish?)..slip the clutch (not dump it or you will spin er'where)..then just go thru the gears. And when you get to the end..rip the e-brake and slide sideways across the line as if you were on Forza.
Old Sep 6, 2011 | 04:09 AM
damastah's Avatar
e-brake does not hold the car.... rear wont lock up, back end wont slide out.... what should i do?
Old Sep 6, 2011 | 04:27 AM
FrossB's Avatar
Thread Killer
well i guess just turn real hard then slam on the brakes...it works on my 360 so its gotta work in real life
Or better yet....install two e-brakes. then they will hold
Old Sep 6, 2011 | 03:14 PM
damastah's Avatar
am i allow to stop before the finish line, do a 180. and do a j turn right on the line?
User 60923
Jan 2, 2016 10:36 AM
dieGone
Sep 23, 2015 10:20 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
toledobalt
Sep 3, 2015 10:27 AM
