Drag Racing Kindle Racing and Dalcorp Racing
Trouble at the track!!
Old Jun 16, 2008 | 02:18 PM
  #51
step n up 09's Avatar
1.Not the axle,
2.I should be running that
3. yes I have a front mount OH YEAH!!
Old Jun 16, 2008 | 02:26 PM
  #52
CobaltSS 16's Avatar
Originally Posted by step n up 09
1.Not the axle,
You need more then just a H/E with that 2.6... get meth.
Old Jun 16, 2008 | 02:37 PM
  #53
SSmoke1's Avatar
I've been running 14.5-14.7@ 97-96 mph with stge 2 2.9 gmpp catback. But i believe Mine has to do with elevation.
Old Jun 16, 2008 | 03:09 PM
  #54
ralliartist's Avatar
what cooling mods? none? if so, then it has more to do with heat. 97-96 is crap trap for 2.9 pulley with exhaust.
Old Jun 16, 2008 | 03:48 PM
  #55
Psykostevo's Avatar
1.Not the axle,
I'm going to need proof that it was not the shift linkage. Most likely you blew out your drivers side axle. It will FEEL like you broke your shift linkage, unless you've done it before then it becomes a warm shitty feeling.
Old Jun 16, 2008 | 04:23 PM
  #56
SSmoke1's Avatar
Problem is I ran that when it was 40 degrees out I ran 14.7 when it was 95 degrees. I am also at 4000 ft above sea level. so hell I dont know. I do plan on getting nitrous soon so I get the cooling and the hp
Old Jun 16, 2008 | 04:52 PM
  #57
an0malous's Avatar
4000ft will certainly explain alot of your et/trap woes.
though with a 2.9 S2, you should still be hitting 100mph...
i would expect your times to be more around the 14.1-14.3@ 100-101mph area
14.5 is a decent time though with only 97mph at the traps.
so it appears its not your driving
Old Jun 16, 2008 | 07:04 PM
  #58
yea, I don't think it's his driving either. I think it's the power output. although the elevation has partly to do with it, the heat is the major issue here. whatever the outside temp is, isn't going to affect your iat2's that much. the blower is just spinning and making heat and the laminova cores aren't getting cooled efficiently with just the stock h/e. that's the problem right there.
Hugger1975
Oct 15, 2015 03:28 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Extremespeed
Sep 29, 2015 04:34 AM
Extremespeed
Sep 1, 2015 09:05 PM
