Drag Racing Kindle Racing and Dalcorp Racing
Went to Drag strip.
Old Aug 7, 2011 | 06:52 PM
startingline05's Avatar
Originally Posted by srt-10
Lower your tire pressure to 27psi...rev to 2500-3000rpm and feather the clutch out as u roll onto the gas. If you feel the car wheel hopping...get of the gas right away.
you make it sound so simple. you must have done that before
Old Aug 7, 2011 | 06:58 PM
Joemaster70's Avatar
Originally Posted by RooTBeeR
whats so funny? They do what there supposed to. And i have no wheel hop.
Old Aug 7, 2011 | 07:01 PM
5 dollars says if you run at the track again with 40 psi in your front tires you will still get wheel hop or either spin really really bad
Old Aug 7, 2011 | 07:02 PM
tires are at 30lbs on the street and i don't have wheel hop. when i go back ill lower them. i never wheel hopped when tires were at 40lbs only spun like crazy.
when i lowered em they hopped bad
Old Aug 7, 2011 | 07:08 PM
srt-10's Avatar
well to get a good time u have to find a pressure so the tires wont hop or spin...lol. Its actually pretty simple...lower to 25-27psi...avoid the wet box..there is no need to do a burnout or go through the box...if u cant avoid it then roll through the water and do a quick burnout on the dry part in front of the box to get the water off your tires. Dont stage your rpms to high and dont slam the gas when you take off...roll onto the throttle.
I would suggest getting a ingalls TD and OTTP rotated mounts...they will help alot.
Old Aug 7, 2011 | 08:24 PM
whats wrong with my TTR mounts they do the same exact thing? i will get a motor mount next and be done
Old Aug 7, 2011 | 10:32 PM
srt-10's Avatar
im not getting into the debate between TTR and OTTP. But i had OTTP's stage 2 rotated mounts and a Ingalls TD...no wheel hop at all at the track.
Old Aug 7, 2011 | 11:59 PM
if i get wheel hop ill let everyone know that these suck until then i haven't had a issue
Old Aug 8, 2011 | 12:02 AM
D-mac's Avatar
Going to need tires to get your 60's down
Old Aug 8, 2011 | 12:14 AM
RooTBeeR's Avatar
how are the vibes?
Old Aug 8, 2011 | 11:30 AM
  #36
they are there but honestly makes it feel more real. car shifts better 2
Old Aug 8, 2011 | 04:49 PM
  #37
87gn06gto07irl's Avatar
If you want some real mounts i have some available in my sig.
Old Aug 8, 2011 | 05:07 PM
  #38
ill stick with mine till something goes wrong
Old Aug 8, 2011 | 05:13 PM
  #39
ItalianJoe1's Avatar
Solid CAB's will work better than rotated mounts for track duty.
2.5 60' times are way, way off. Should be able to manage a 2.2 easily, and dropping .3 at the start will get you over a half second off your times. That alone will put you into the normal range.
jcalvin1126
Oct 26, 2015 12:31 AM
Hugger1975
Oct 15, 2015 03:28 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
QuickSilver_SS
Sep 17, 2015 05:38 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
