1st, 3rd, 5th are fine: No 2nd, 4th, or Reverse?
I considered getting that upgraded bracket but rumor has it that the "Upgraded LSJ Shift Bracket" is just the stock OEM LNF bracket.
Thanks for the help guys.
It is just an LNF bracket, it even says so on ZZP's website: "This is a GM revised shifter bracket for the LSJ." the GM part number listed at the top right brings it up on a GM catalog
ZZP charges just under retail pricing for it at $28+shipping, GMpartsdirect has them for $30shipped, see if your dad's friend can snag you one GM part# 55563732
https://www.cobaltss.net/forums/08-1...hatter-277445/
Might be a little bit interesting info. Tried to keep my post updated and informative ..
Yea, like I said man it's no big deal. Nothing to complain about on my end, I just wish I wasn't having these problems! It's such a fun car to drive and it's killing me to have to take it in 2 days after buying it.
I go up to Traverse City every year and we roll through Cadi to pit stop at the Macd's right on the lake. I'll let you guys know this summer just in case something works out.
The shop I took it to said the end case needs to be replace due to a large crack across it as well as two huge dents (cause of the leak). He also mentioned that the bolts to mount it weren't even completely screwed in. I'm not going to point the finger at ZZP but the mechanic said the only way it would have been damaged that bad were either if it was in a huge front end crash or if the trans was dropped. It was "bone dry, not a drop of fluid" as he put it and said if I had drove on it another few days I could have blew the trans which scared the hell out of me. A nice price tag followed which didn't make me smile.
I just got my car back from the shop, $514 to replace it which seems a bit steep for me but I guess I'm not fully aware if they had to drop the engine out of it to get that end-case off. For the end case alone straight from GM they charged me ~$160! Wish I would have talked to you a few days ago man, the money i'm dumping into this is killing me for just getting it
I was considering having him snag me one while he was at it but he's already getting me $100+ shift cables for free or pennies so I wasn't going to push my luck. The bracket seemed ok and worst case and I can just snag one off of ZZP for the 28 bucks, that doesn't worry me too much.
If it's the same part though what's the point?
I got the thing jimmy-rigged to shift with some heavy-duty tie wraps. Shifts perfectly and should hold until I get my new cables in so at least it's working at the moment.
Can throw a picture up if anyone wants to see it for future reference, haha.
When i damaged my stock IC i used JB weld to seal it up enough until my MPx IC arrived.
Props man!
Digging up an old thread but this has just recently happened to me, 1,3,5 all shift in nicely 2 and 4 are a little different though. It feels like I am hitting a wall when shifting into these gears. To get it to go in I have to use both hands and bend the shifter back real hard. Once it does go in when I shift out its stuck and i literally have to use both arms to push the shifter out.
But here is the kicker it only does it when its below 35 deg out. Any time above 35 and it doesnt exactly shift smoothly like 1,3,5 but it goes into gear.
I have removed the cup holder and the things are all still in place, nothing is broke by the mount on the trans and the endlinks are secured just fine. Should I try readjusting the right cable?
You'll probably have to replace the cables. Will be smooth as butter afterward. The shield over the cables eventually gets brittle and shrinks around the actual cable in cold temperatures.
Its gotten worse as the winter has gone along, Today i couldn't even get into 2nd or 4th and I barely grabbed reverse when I backed into my spot at home. I am gonna call around to dealerships tomorrow to get it in. Its too cold for me to be laying on the ground for a day.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
