Bad Axle???
Bad Axle???
Ill start off by describing the problem im having and list what ive done so far.
Car has 100k Flatt ive had the car for about 2 months now been replacing alot of neglected things. Stock suspension and all mounts as far as I can tell.
About 2 weeks ago I started getting a slight Vibration when turning right at anything over 20mph. naturally I inspected the tires and noticed the front tires had a bit of dry rot on them. so I rotated the tires to the back that had fresh tires on them and no change.
Got to the point where the vibration became severe so since i heard no clicks or popping I replaced the passenger side Wheel bearing since thats the side that was loading up.|
No change. my next step would be to inspect the axles since i know they are problematic on these cars. But i wanted to see if there was anything else you guys know about on these cars that could give me similar symptoms. Any bushings Etc.
Thanks
-Chris
Thanks
-Chris
DANRICKARD
Oct 1, 2015 12:08 AM
Iceberg
Sep 29, 2015 12:33 PM
