Best aftermarket clutch for LNF?
As the title says, What ones the best? I'm pushing around 350 lb/ft, and won't be going any higher. Looking for as close to stock pedal feel as possible since it is my daily driver, and traffic is a bitch. I'll be getting an LSD installed shortly so i figured might as well grab the clutch while the trans is down.
Anyone have any ideas, i looked around through search but there doesn't really seem to be any sort of an agreement as to what is the best or what to even stay away from.
All work fine if the parts are correct and the install is done right. My SPEC Stage 2+ with the LWFW is a bit stiffer than stock but takes everything I throw at it. Some chatter when cold, had to install an adj rod from ZZP to raise the pedal off the floor at engagement.
Stock FW I would have picked the ZZP Stage 4 but I don't know how stiff it is. I needed over 400 ft/lbs tq though.
Exedy clutch and flywheel is good also but I think also stiffer than stock.
Hard to hold torque and keep a soft pedal feel.
THe LWFW took a bit of time to get used to for a DD.
patooyee
Oct 1, 2015 01:07 PM
