Best aftermarket clutch for LNF?
Old Sep 28, 2010 | 01:27 PM
loki141's Avatar
As the title says, What ones the best? I'm pushing around 350 lb/ft, and won't be going any higher. Looking for as close to stock pedal feel as possible since it is my daily driver, and traffic is a bitch. I'll be getting an LSD installed shortly so i figured might as well grab the clutch while the trans is down.
Anyone have any ideas, i looked around through search but there doesn't really seem to be any sort of an agreement as to what is the best or what to even stay away from.
Old Sep 28, 2010 | 03:01 PM
Iam Broke's Avatar
All work fine if the parts are correct and the install is done right. My SPEC Stage 2+ with the LWFW is a bit stiffer than stock but takes everything I throw at it. Some chatter when cold, had to install an adj rod from ZZP to raise the pedal off the floor at engagement.
Stock FW I would have picked the ZZP Stage 4 but I don't know how stiff it is. I needed over 400 ft/lbs tq though.
Exedy clutch and flywheel is good also but I think also stiffer than stock.
Hard to hold torque and keep a soft pedal feel.
THe LWFW took a bit of time to get used to for a DD.
Old Sep 28, 2010 | 03:58 PM
Ferretts's Avatar
I wish RPS made a clutch for lnfs
Old Sep 29, 2010 | 12:15 PM
loki141's Avatar
Anyone have any thoughts on clutchmasters for an lnf?
Old Sep 29, 2010 | 08:37 PM
SSPainter's Avatar
zzp stg 4 /w adjustment rod
Old Sep 29, 2010 | 10:21 PM
blackvette101's Avatar
spec stage 3+ here. a little stiff but nothing too crazy.
Old Sep 30, 2010 | 06:46 AM
glhs379's Avatar
clutchmasters stage 4 6 puck
no issues at all
Old Sep 30, 2010 | 01:56 PM
loki141's Avatar
How's that ZZP feel, and what kind of power are you putting down?
Old Oct 6, 2010 | 08:45 PM
emiller's Avatar
no issues at all
how stiff is it? what kinda power you making?
Old Oct 6, 2010 | 08:50 PM
TurboTechRacing's Avatar
This is my choice for a high HP cobalt.
Old Jun 26, 2011 | 04:02 PM
northvibe's Avatar
There were many raving about a ky clutch..I think that's the name
Old Jun 26, 2011 | 05:42 PM
slowstang's Avatar
no issues at all
Same clutch with a matching aluminum flywheel. I'm only at 350 miles on it so far. Very easy pedal feel with alittle bit of chatter while taking off. It seems to be getting better as the mileage goes up.
Old Jun 26, 2011 | 05:52 PM
AndrewSS/TC's Avatar
I plan on going with KY clutch.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
