car problem :(
Old Dec 2, 2011 | 12:56 AM
ikeryder13's Avatar
car problem :(
my car is becoming harder everyday to shift gears... every gear it is hard to shift into... and at WOT I can barely get it into 3rd... on top of that when I accelerate my.front end shakes alot... I'm hoping my shifting problem is just I need a new TOB and the shaking might be my axles going out or I need new wheel bearings... any ideas?
Old Dec 2, 2011 | 01:05 AM
Chevycobaltss3's Avatar
Well Ure issue gear wise can be a tension pin or so called the roll pin. It's in between the linkage and the shifter ARM on tranny. Or it can be Ure clutch / t.b. with the shaking first look into wheels and balance then rotors and pads and then bearings.
Old Dec 2, 2011 | 01:56 AM
ikeryder13's Avatar
yeah I'm.gonna replace the tob this next week.. I have a spec 2+ clutch and the rotors and pads.are all still good I.hope... I have a rotora big brake kit... how hard is it to replace the pin?
Old Dec 2, 2011 | 09:51 AM
It's not hard to replace the pin at all. If I were you I'd inspect the friction disc.. and get Ure pressure plate chcked out.
vjoel2011
Oct 2, 2015 12:11 PM
Dope_SS
Sep 13, 2015 05:24 PM
Wind
Sep 11, 2015 06:57 PM
ATOMbomb
Sep 11, 2015 10:48 AM
jthwjde
Sep 7, 2015 09:24 AM
