Which Clutch
Which Clutch
I am going to have a clutch installed in the spring and i am not sure what is going to be a good one to go with.
I feel if you go big the first time it will be better so it doesnt have to be changed later..I know that driveability it always a thing to look at.
I have looked at the Spec 3+ 6 puck or Spec 3 six puck. Or even the 2+ 6 puck.
Thanks
Mike
Thanks
Mike
i can get ur stock clutch buit threw my work with a spec whatever disc u want for about 225 shipped with ur flywheel resurfaced, and a new slave cylinder for 75 dallors just throw me a pm if ur interested. thanks ronnie
then i'll buy one
Last edited by selfinfliction; Jan 8, 2010 at 09:13 PM. Reason: Automerged Doublepost
you know what ill have u a answer for that monday when i go in. Ill ask my boss and see what he has to say, cause really i didn't ask for any of this bs so this **** could die for all i care, but yea ill ask.
you're trying to say that a clutch with the oem pressure plate will hold as much as the higher end SPEC/CM/ACT when the pressure plate itself is the weak point of the clutch.
back to the OP, get a spec
Not to be negative but every spec clutch ive had has fell apart and not due to hard driving or bad install. However they claimed fault and always sent new ones. But imo Exedy is the way to go on these cars.
