View Poll Results: Help me choose a new Clutch
OEM Stock
3.23%
GMPP
18
58.06%
Spec
9.68%
ZZP Stage Clutch
12.90%
Other: Please specify
16.13%
Voters: 31. You may not vote on this poll
Clutch Advice
Old 05-04-2012, 11:29 AM
insylem's Avatar
Clutch Advice
Hey Everyone,
Ive been having clutch issues lately. When the engine is reved, my clutch does not want to disengage properly, leaving me locked into gear.
Ive changed/flushed/bleed my clutch fluid, and it came out black with floating things in it.
However a test drive revield that my problem still exists....
So the only thing I see that could shed more light is to take the clutch apart and look.
So I would like opinions, advice on a new clutch
Also should I get the ZZP Upgraded throw out bearing?
Old 05-04-2012, 11:35 AM
bluebalt07's Avatar
I voted other and I think you should look at the KY clutch. Can't beat the quality for the price. And yes you should get the TOB from ZZP
Old 05-04-2012, 11:39 AM
TurboTechRacing's Avatar
Other! KY Clutch @ Turbo Tech Racing, best in value and price.
We sell the TOB with the kits, it is the "upgraded LNF" one for all kits (2.0L based)
Old 05-04-2012, 12:01 PM
insylem's Avatar
Is this the one you're takling about?
KY Clutch - Chevrolet Cobalt/HHR 2.0L F35 Trans Stage 1 - Turbo Tech Racing, LLC
Old 05-04-2012, 12:05 PM
094doorSS/TC's Avatar
go with ky save some bucks.
Old 05-04-2012, 12:24 PM
insylem's Avatar
Is the quality still great?
Old 05-04-2012, 12:30 PM
i just got mine in two days ago, looks good i will let you know more when i get it in next weekend, but I've heard nothing but good things about them.
Old 05-04-2012, 12:33 PM
insylem's Avatar
Awesome Thanks. Ive never heard fo KY Clutches before. Always makes me nervous about things i've never heard of, Just afraid of things I dont understand I guess. I tried to find reviews on google but coudln't
Let me know,
Thanks,
-Jonathan
Old 05-04-2012, 12:35 PM
SaberD's Avatar
what are your mods? any plans for future mods?
Old 05-04-2012, 02:36 PM
insylem's Avatar
All my mods
Good question: I should have said in my original post
According to my last dyno run:
Max Power = 239
Max Torque = 219
Dyno Boost = 15
1/4 Track Boost = 18
I would estimate that Im in the neighborhood of 240 - 250 whp on the gound.
Mods are:
  • Ingalls Torque Dampner (Baught Car with)
  • DC Sports Strut Tower Bar (Baught Car with)
  • OTTP Stg1 front mount with rear spacer
  • OTTP Stg1 H/E
  • Dual Pass Endplate
  • LSJ Pheonalic Spacer
  • 2.85" Pulley (Baught Car with)
  • Simmons 60# Fuel Injectors
  • Fuel Injector Harness (Baught Car with)
  • ZZP Canned Tune
  • Dual Interceptor Setup
  • 3 Gauge Pod A-Piller
  • Analogic Gauge replacing Stock Boost Gauge
  • 3 Bar Map Sensor Kit
  • EGT Probe
  • Fluid Sensor Kit installed in OTTP Stg1 Heat Exchanger
  • Custom Termnal Board where Option B mounts for various sensors
  • ZZP 3" Intake
  • ZZP Long Tube Header
  • ZZP 3" Catted Downpipe to stock exhaust
  • Oil Pressure Sensor / various plumbing to connect to Oil Galley Port
  • Fuel Pressure Sensor/ Plumbing to connect to Fuel Rail Shrader Valve
  • Wideband Sensor kit
  • Hurst Shifter (Baught Car with)
  • K&N Dry Charger for Filter on ZZP Intake
  • Undersize Belt/Oversize Tensioner Pulley (Don't know wich as it came used this way)
  • Ceramic rear disc brake pads
  • High Temp PVC Pipe for running wires over the back of my engine bay
  • Heat Reflector over the High Temp PVC Pipe
  • Stock Header Heat Shield removed due to not fitting with the ZZP Header
  • Steel braiding over most hoses
  • Plastic covering over other hoses
  • Jensen VM9224 Reciever w/ steering wheel wire harness
  • Backup Camera
Feuture Planned Mods
  • Upgradeded Steering Knuckles
  • Oil Pan replacement with Oil Temp Sensor
  • Ceramic Front Brake Pads
  • 215 Wide Tiers (Maybe)
Old 05-04-2012, 03:50 PM
alleycat58's Avatar
Seriously get the GMPP clutch. I love it, handles the 345whp like a charm.
Old 05-04-2012, 04:09 PM
Quality is the best. It is the hotest selling clutch for the cobalt for us. We ship many kits each and every day of these.
Old 05-05-2012, 07:15 PM
insylem's Avatar
Question : If I"m going to have a new clutch installed. Do I need a new rod? I heard the stock rods like to get bent? Where do I get an upgraded rod? I think I saw one on ZZPs sight though
Old 05-06-2012, 12:30 PM
calicobaltSS's Avatar
I have the GMPP clutch...Im going stage 2 after the sin city bail out comming up here next weekend....the stage 2 can handle up to 300 hp....and....its the same exact clutch that is in the LNF motor( I checked..the part numbers match up)....the stock LSJ clutch goes out due to the pressure plate not being able to handle boost in first gear....thats why it dies early...I got it from CED just like the stage 2....cant beat it....IMO
Old 05-06-2012, 10:41 PM
bluebalt07's Avatar
Some people have issues with the stock rod but not all. ZZP does sell an adjustable one but unless you actually bend yours or don't like the engagement point of the new clutch its not really necessary
Old 06-06-2012, 02:53 PM
insylem's Avatar
Well, since the GMPP clutch won by alot that's what I went with. I baught the better TOB from OTTP since ZZP was sold out. I just got my GMPP clutch and steering knuckles today. Clutch came with the better TOB so let me know if anyonw wants to buy an unused TOB as now I have two.
Made appointment with the shop for monday. Now I must make transportation arrangments as its an all day job.
Old 06-06-2012, 03:09 PM
i love my gmpp
Old 06-08-2012, 10:03 AM
KY stage 3, stock/OEM flywheel, no adjustable clutch rod is needed.
Old 06-11-2012, 01:14 PM
insylem's Avatar
Update:
I dropped my car off at the shop thismoring . Clutch has been having issues, not disengagning after reving over 5500 rpm. Well, The guy at the shop just called and said that I had a aftermarket Spec Clutch. I thought I heard it rattleing a few times. Haha I had no idea the previous owner had replaced the clutch already I thought I was still on the stocker. Well anyways, I got the GMPP clutch. He said when he took it apart, that they didnt see anything wrong. That kinda suprised me. I was expecting SOMETHING to be messed up. Well the GMPP clutch needs a diffrent flywheel then the Spc, so that wont be in till tomarrow. If he gets it noon tomarrow he should have it done by COB Tomarrow wich ill be at work so I can probably get it wensday.
Old 06-11-2012, 01:39 PM
Sully20's Avatar
^^^THIS, Cant beat the Bang for the Buck and its got a little bit stronger than stock feel
Old 06-11-2012, 01:53 PM
insylem's Avatar
Yup already have the kit, PN 19212712
See websight Ecotec LSJ Clutch Upgrade Kit 19212712
But the shop called, said they have to change the flywheel, since some one put a spec clutch on it before I baught it. He said they were diffrent sizes. So tomarrow arround noon the new flywheel comes in. Yay Hes getting it from the local dealership.
Hopefulyl this will fix the issues Ive been having. He said they didnt see anything wrong and one of the guys was like "Why are we changeing the clutch?"
I told him how it goes above 5500 rpm and it doesnt want to disengage properly. Hopefully I can get my car back Wensday, as they hopefully will be done with it Tuesday, but I have to work so Ill have to ge i before work wensday.
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Clutch Advice
