clutch bleeding issue.. Need help!!!
so the car is done and runs.. the issue with everything the throw out bearing needed to be bench bleed... when i pulled the trans out and had just about all air the in the throw out bearing... it would of taken me years to bleed that **** out... i just ended up ordering the stock flywheel... cuz if for some reason it didnt work i would of bugged out... the fidanza flywheel deff would of worked... its not off by much from the stock flywheel..... now i just need a adjustable clutch rod...
