clutch question
Old May 21, 2008 | 09:07 PM
07cobalt4life's Avatar
clutch question
me and my dad just installed a exedy clutch. of course we got the flywheel turned. but the question i have is when u go an engage the clutch u barely have the move the clutch to engage it i was just wondering if that is normal for this clutch
Old May 22, 2008 | 06:08 AM
bump someone has to have this clutch
Old May 22, 2008 | 05:10 PM
Old May 22, 2008 | 05:16 PM
BlackSS/SC's Avatar
Please tell me you put a new slave cylinder in it.
Old May 22, 2008 | 05:22 PM
no i didnt why would i need to replace that?
Old May 22, 2008 | 05:29 PM
BlackSS/SC's Avatar
Research > You
Everything you drop the transmissions in these cars you need yo change the salve/throwout bearing assembly. I did what you did way back and had to drop the transmission again and change it.
Don't know if that's your problem for sure but sounds like how mine was.
Old May 22, 2008 | 06:15 PM
but why would it suddenly do this with this clutch when it didnt do it with the stock clutch?
Old May 22, 2008 | 06:39 PM
BlackSS/SC's Avatar
It's normal, you disturb the clutch stuff and it never works the same again. Thus why you replace the slave too.
Old May 22, 2008 | 06:54 PM
05OrangeSS's Avatar
I didnt replace mine when I had the exedy installed. I put 20k miles on it and it was fine. I dont know how it is now because I dont have the car anymore. What do you mean you turned the flywheel? The exedy comes with new everything, so I dont know what you mean.
Old May 22, 2008 | 07:06 PM
BlackSS/SC's Avatar
I just noticed he said he had the flywheel resurfaced, which is also a bad thing on these cars. You have to replace the whole flywheel or you mess with tolerances.
Most of the time if you don't replace the slave you will have problems.
Old May 22, 2008 | 07:10 PM
JPizzle's Avatar
X2 ^^^^
1.) Replace Clutch
2.) Replace Flywheel
3.) Replace Slave Cylinder
(Not necessarily in that order).....
Old May 22, 2008 | 07:54 PM
mrniceguy8211's Avatar
I have a Spec stage 2, I replaced the Slave, but had the stock flywheel resurfaced. I would have to agree with Black ss/sc, bad move to resurface these flywheels. My clutch still doesn't work correctly, I have to fitness it to get it to engage correctly. I am going with a lightened flywheel and a non Spec clutch next time.
Old May 22, 2008 | 09:44 PM
SymbioteLT's Avatar
replace flywheel even for the 2.2?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
