clutch question
clutch question
me and my dad just installed a exedy clutch. of course we got the flywheel turned. but the question i have is when u go an engage the clutch u barely have the move the clutch to engage it i was just wondering if that is normal for this clutch
Research > You
Everything you drop the transmissions in these cars you need yo change the salve/throwout bearing assembly. I did what you did way back and had to drop the transmission again and change it.
Don't know if that's your problem for sure but sounds like how mine was.
I didnt replace mine when I had the exedy installed. I put 20k miles on it and it was fine. I dont know how it is now because I dont have the car anymore. What do you mean you turned the flywheel? The exedy comes with new everything, so I dont know what you mean.
Most of the time if you don't replace the slave you will have problems.
I have a Spec stage 2, I replaced the Slave, but had the stock flywheel resurfaced. I would have to agree with Black ss/sc, bad move to resurface these flywheels. My clutch still doesn't work correctly, I have to fitness it to get it to engage correctly. I am going with a lightened flywheel and a non Spec clutch next time.
