Clutch Selection
Old Aug 15, 2012 | 05:49 PM
blueLNFftw's Avatar
Clutch Selection
Have a 2006 SS/SC with almost 60k now.
Currently its stock with a GM Stg 2 kit.
Pretty sure the slave is going/bad so a member here and myself are going to replace it with the LNF one. Since the trans will be open I want to toss in a new clutch kit as well. Been looking at the GMPP kit or a South Bend kit from ZZP. Which should I go with?
Future goals include keeping the m62 and upgrading to stage 3 with a custom HP Tuners tune. This will probably be installed by spring time along with a ZZP long tube, 3" DP, Intake, dual pass option B, OTTP heat exchanger, and suspension.
Old Aug 15, 2012 | 06:07 PM
TurboTechRacing's Avatar
KY Clutch!
Old Aug 15, 2012 | 06:10 PM
the gmpp can support 300whp or torque, i'd go with that.
right now i'm stg2 (ottp 2.8 & 60#s) and longtube header/dp and intake pretty much.
i replaced my clutch with gmpp along with all the other lnf goodies like the shift linkage and slave. everythings fine, never slips! bite point is right at the bottom of the pedal and feels great. along with zzp axles and a short shift my car feels MUCH stronger than before. -- i know this because i test drove a balt with just stage 2 nothing else and it felt ...weak
if nothing else for the price u just can't beat it
Old Aug 15, 2012 | 06:13 PM
Facepalm_IRL's Avatar
GMPP clutch is worth its weight in gold if your not planning an ultra high hp build. Its the only way to go. AND it comes with an LNF TOB
Old Aug 15, 2012 | 10:20 PM
Sharkey's Avatar
if you have a daily driver that you ocasionally may take to the track, the gmpp clutch is plenty. it holds enough power for what 90% of what people are doing, has good engagements (doesnt chatter) and has a stock pedal feel. really, you cant ask for anything better.
Old Aug 15, 2012 | 10:22 PM
jp1600's Avatar
I have the act hd clutch, love it, car grabs fast as hell
Old Aug 15, 2012 | 10:28 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Gmpp clutch. Don't ask me how but it's holding 450+whp. Can't ask for anything more from it. Drives like a factory clutch.
Old Aug 15, 2012 | 10:36 PM
turbosmart4's Avatar
I've never heard any complainf about KY or GMP clutches, any of those would be good IMO
Old Aug 16, 2012 | 10:56 AM
blueLNFftw's Avatar
Ive looked around and I am going to go with the GMPP. Should be perfect for my goals and it seems to be the most cost effective solution.
Old Aug 16, 2012 | 11:30 AM
Sully20's Avatar
this. Thier is no camparison with any other clutch, Get the GMPP its the BEST bang for your buck and will hold just about anything you can throw at it! I had it in my s/c and LOVED it! I only wish their was something similar for the LNF.
Old Aug 16, 2012 | 11:48 AM
Gelladuga69's Avatar
I have this kit as well.
GM11-HDSS
Old Sep 11, 2012 | 07:12 PM
blueLNFftw's Avatar
Quick question before ordering.
For my 2006 SS/SC
Ecotec LSJ Clutch Upgrade Kit 19212712
Cobalt Clutch Pipe 24422067
Then from a 2009 SS/TC
Just the slave cylinder (no part number listed)
Are these the only things I need to do my clutch? Already have an alignment tool.
Old Sep 11, 2012 | 07:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
The clutch kit already comes with a new slave/throwout bearing
Old Sep 11, 2012 | 07:27 PM
Chevycobaltss3's Avatar
I'd honestly love proof of a Gmpp clutch holding 450ftlbs since clutches are rated at ft lns and not whp. Id also like to see proof of people with the Gmpp having more then 350whp without blowing the clutch.
Old Sep 11, 2012 | 07:45 PM
blueLNFftw's Avatar
But does it come with the better LNF one or with a replacement LSJ one?
Old Sep 11, 2012 | 08:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
The next dyno day that comes around, you will have your proof. S256et on 25.5psi, e85 and 24* of timing. Gmpp clutch like a champ
It comes with the LNF tob
Last edited by BLAZIN07SS; Sep 11, 2012 at 08:27 PM. Reason: Automerged Doublepost
Old Sep 11, 2012 | 08:31 PM
blueLNFftw's Avatar
awesome. saves me some cash. ordering the kit and clutch pipe from GM parts direct.
Old Sep 11, 2012 | 11:15 PM
Sully20's Avatar
Hope you dont get a faulty LNF TOB, I'm on my 2nd one and the 2nd one is a piece of garbage too, Looks like Imma need to get another one, All within a 4 week period! It makes a ton of noise, I wouldnt wish this on my worst enemy! GM is having a TON of Issues with the LNF TOB right now. ZZP dosent even stock em anymore.
Old Sep 12, 2012 | 12:40 AM
blueLNFftw's Avatar
Do you have a link or something discussing it? I would go with another LSJ one but I am under the impression they don't make it anymore and replacements are left for the LNF TOB.
Old Sep 12, 2012 | 01:17 AM
slapbetcommissioner's Avatar
Bluelightning is running the gmpp with an aggressive tuned tvs. He's at least at 300wtq If not better. Drag radials and 7krpm launches. It's sticking the power no problem.
Old Sep 12, 2012 | 01:16 PM
blueLNFftw's Avatar
In not concerned about what it holds, there are tons of threads about that. I just want to be sure I'm buying everything I need.
Old Sep 13, 2012 | 08:44 AM
Sully20's Avatar
Just E-Mail ZZP and ask them, Believe me they'll tell you. I would get a LSJ one, Trust me its been a Nightmare with the Faulty LNF TOB's, You can also call Crate Engine Depot and ask them, They will also confirm the Bad LNF TOB's.
Old Sep 13, 2012 | 07:56 PM
olmstt30's Avatar
im also on the same debate on the lsj or lnf one i have a 06 lsj stage 3 s/c just about to get the turbo kit for it and not sure what one to get yet
Old Sep 13, 2012 | 08:10 PM
blueLNFftw's Avatar
Can you even get LSJ TOB anymore? I thought lnf ones replaced them
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
