F23 Fluid Compatability
Old Apr 7, 2009 | 01:10 AM
senior_brown's Avatar
Canada F23 Fluid Compatability
just wanting to know if anyone with a non supercharged/turbo model has used anything but the atf that came in the trans?
if so what did you use and how did it affect it?
im considering switching to syncromesh fluid or gear oil..
any input?
Old Apr 7, 2009 | 01:27 AM
Sharkey's Avatar
if you go to syncromesh or gear oil you will burn it up from lack of lube. the transmission is designed for atf, which is very thin. thick oil like syncromesh or gear oil cant get through the lube passages sufficiently and will cause it to overheat from lack of lube and turn into a ball of junk.
feel free to try synthetic atf if you feel so inclined, or a fluid designed specificly to replace atf is a manual transmission
Old Apr 7, 2009 | 01:30 AM
2MCHBoost's Avatar
Anyone tried MAX ATF in it yet?
Old Apr 7, 2009 | 01:37 AM
i havent found a fluid to replace atf in manual trans yet, but i have been leaning toward mobil 1 synthectic atf,
anyone else got input?
Old Apr 7, 2009 | 05:23 PM
Dave7417's Avatar
Jpunishment has Mobil 1 in his 2.2
I put Amsoil ATF in my 2.4 last month. Marginal difference at this time of year, although I suspect I might have noticed more of a difference in the middle of winter. The trans feels slightly "lighter" if that makes sense. There was little difference over OEM Dexron VI.
I imagine someone with an older car with Dexron III, who replaces it with Dexron VI might notice a slight improvement. But that is just a guess on my part.
Old Apr 8, 2009 | 02:24 AM
i thought the auto trans uses dexron 6 and the 5spd uses dexron 3?
Old Apr 8, 2009 | 12:39 PM
Dave7417's Avatar
My 08 manual specs Dexron VI
Old Apr 9, 2009 | 07:36 PM
yea im pretty sure my 06 manual says dexron 6 as well...
Old Apr 9, 2009 | 08:11 PM
Maven's Avatar
The F23 uses Dexron type ATF only. All of them can use Dexron VI spec fluids, Redline D6 is nice but isnt technically a GM certified fluid. 05-06 cars originally came filled with Dexron III and can use Dex VI or any fluid that exceeds Dexron III specs, I personally really like Mobil 1 ATF and put it in every manual trans that originally had DexIII in it. never any issues.
Old Apr 9, 2009 | 08:13 PM
BIG-DAVE's Avatar
Only use the auto trans fluid in the f23 trans stick or auto they both take the same. Gear oil and stuff is to thick for our transmissions
DarrenGC
Dec 24, 2021 01:55 PM
hhrfreek
Jun 4, 2016 11:25 PM
Tupp
Sep 29, 2015 11:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
Sean Cummings
Sep 11, 2015 09:35 PM
