Front End Issues
Old Jul 17, 2013 | 01:52 PM
Cobe's Avatar
Front End Issues
So the Balt is getting kinda loud up front towards the right. It sounds like a spinning noise or a rotating noise. You hear it more as you go faster. It sounds like the front right wheel bearing and I think it is because now I think the left one is starting to go too. You can hear the noise on both sides. But I am not sure. Also now shifting into gears you can hear my throw out bearing I think... It makes a noise while trying to go into or take out a gear. Its quite but very noticeable. Also when the car is in 5th and Im just cruising at like 60 I can hear the noise coming from the throw out bearing if thats what that issue is.. Because its the same damn noise.
So I have no idea... Anyone can chime in... I think new tranny fluid or a new throw out bearing and new wheel bearings... But if anyone else has had this issue please help
Old Jul 18, 2013 | 01:32 PM
Cobe's Avatar
so this is a new thing? I think not. I think I am going to start with getting new fluids... what do you guys run in your transmissions?
Old Jul 18, 2013 | 01:36 PM
jonathan923's Avatar
sounds like a wheel bearing man, easy fix..if it was something more based on ur TOB you would most likely be having clutch issues as well...
Old Jul 18, 2013 | 01:42 PM
noorj's Avatar
TOB wouldn't make noise when your not on the clutch...
Old Jul 18, 2013 | 02:48 PM
Gelladuga69's Avatar
Hunter, there's a GM part number for the trans fluid floating around here.
Yes, it would. A whirring, for example. Should only be in neutral though.
Old Aug 5, 2013 | 01:10 AM
tuned08ss's Avatar
my TOB is shot and i'm not having clutch issues. when i press the clutch the noise goes away. when its not pressed it sounds like marbles in a can.
Old Aug 5, 2013 | 01:29 AM
buildmeanempire's Avatar
My trans made the same noise.... turned out to be the final drive.
Sent from my Nokia 3100 using CobaltSS
Old Aug 5, 2013 | 01:31 AM
tuned08ss's Avatar
^it made the noise through all gears and neutral? did u get it fixed?
Old Aug 5, 2013 | 02:10 AM
Made noise in gear driving and coasting but no noise with clutch to the floor like you said with yours. Trans was replaced and metal was ran through each gear and pretty much destroying them.... your case could be different though.
Old Aug 5, 2013 | 02:21 AM
tuned08ss's Avatar
yea i just started my own thread about it. dont want to jack the op's. i should've had the dealer fix it since i heard it on day one. just didnt know what it was back then.
Old Aug 5, 2013 | 09:36 AM
sLAsh's Avatar
Start with wheel bearing. Lift car and rotate wheel while holding spring or using a stethoscope. Should be easy to tell if three bearing is gone. If noise still there then move onto other things. No use throwing money at what you"think" it might be. Fix what you know it's broken first.
Old Aug 5, 2013 | 09:41 AM
user 72239's Avatar
mine is doing the same thing. Has been doing it for 6+ months now. only loud when its cold
Solaris99
28
Mar 15, 2017 01:22 PM
nathan112i
Sep 30, 2015 07:12 PM
jmelton327
Sep 26, 2015 10:04 PM
