getrag f23 to f35 transmission swap
Old 04-10-2010, 08:00 PM
olvrqert's Avatar
Can the Getrag F35 transmission be used in place of the Getrag F23 transmission? Engine is L61 2.2 Litre Ecotec? If there is a thread with pics please direct me to it. The reason I'l like to swap out my Getrag F23 for a Getrag F35 is that Morad Parts Company has used F35 Transmissions with the LSD option a lot cheaper than having to buy and install the Quaife LSD for the Getrag F23.
Old 04-10-2010, 08:08 PM
MP Cobalt's Avatar
f35 only bolts up to the lsj bottom end i believe.
Old 04-10-2010, 08:14 PM
07cobaltguy's Avatar
i think the bell will physically bolt up but i belive there are quite a few other differences that would be expensive to overcome.
Old 04-10-2010, 08:19 PM
elecblue06's Avatar
not true.. F35 can be used.. but you need to buy a fly wheel from a L200 saturn..
it hasn't been done but technically it should work..
the L200 comes with the F35 and it has a 2.2 ecotec.
so yeaa.. put 2 and 2 together.. it's possible.. but it needs to be done..
hell someone on redline forums mated an F35 to a 2.4 bottom end.. he had a custom flywheel / clutch made because he wanted the lager clamping force.. but really you cand do it all with stock parts..
Old 04-10-2010, 08:22 PM
MP Cobalt's Avatar
well if your swapping trannies for performance i dont want to run a stock flywheel from some l200
Old 04-10-2010, 08:48 PM
elecblue06's Avatar
who the hell said you had to use the stock flywheel. lol
you can get a fidanza flywheel
http://www.partstrain.com/ShopByDepa...el/saturn/l200
womp google fail
Old 04-14-2010, 11:08 PM
intel's Avatar
Hey olvrqert,
I was going through the same thing that you were debating on. If you want more information I'll post a link to my thread that discussed it as well.
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/transmission-swap-210453/
05-28-2022 03:47 AM
RaginChopsuey
10-27-2015 01:27 PM
ThoR294
10-04-2015 08:44 PM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
Quick Reply: getrag f23 to f35 transmission swap
