GMPP clutch
Old Mar 21, 2013 | 12:37 PM
duffman11's Avatar
GMPP clutch
I have read that people are using the GMPP clutch for their LNF. I E-mailed Tom @ CED he wasn't 100% sure what I wanted specifically.
I was wondering if someone could spell it out for me. I don't want to buy the wrong parts and have my transmission torn apart and not have the correct parts to fix everyting.
Old Mar 21, 2013 | 01:07 PM
turbosmart4's Avatar
I believe they don't make gmpp clutch for lnf..... Supposely, the lsj gmpp is the lnf clutch? Which is an upgrade for 05-07s?
But someone can correct me if I'm wrong.
Last edited by turbosmart4; Mar 21, 2013 at 01:07 PM. Reason: Automerged Doublepost
Old Mar 21, 2013 | 01:13 PM
rivaladore's Avatar
Yes it will work. Ask dartsi he is running it on his lnf
Old Mar 21, 2013 | 02:12 PM
duffman11's Avatar
I am wondering what he bought exactly. Tom@CED isn't sure about it.
Old Mar 22, 2013 | 05:58 PM
duffman11's Avatar
Bump!!!!!!!!
Old Mar 22, 2013 | 06:01 PM
Wert842's Avatar
Ecotec LSJ Clutch Upgrade Kit 19212712
Old Mar 22, 2013 | 06:27 PM
duffman11's Avatar
I figured that is it. Do I need i different amount of bolts? Which ones, what about the pressure plate do I need a different one?
Old Mar 22, 2013 | 09:03 PM
rivaladore's Avatar
Like I said pm Dartsi if you want answers. That clutch is holding well for him and he's running an upgraded turbo on his lnf
Old Mar 22, 2013 | 09:26 PM
Powell Race Parts's Avatar
the GMPP upgrade is an LNF pressure plate with a slightly different clutch disc material and spring package. The GMPP upgrade is 100% compatible with the LNF, installs well, is cheap and is equal to, or better than, a stock LNF clutch. enjoy.
Old Mar 22, 2013 | 09:28 PM
Wert842's Avatar
Powell for the win!
Old Mar 22, 2013 | 09:32 PM
rivaladore's Avatar
He is the man!
Old Mar 23, 2013 | 01:18 PM
vahdyx's Avatar
I'm using GMPP Clutch also. It isn't the same as stock LNF clutch. From what I understand there's similar parts but the capacity is higher with GMPP. It holds more than advertised for sure. I'm still "breaking it in" the safe way. Even though the break in procedure says "drive with caution" for the first few heat cycles.
I am very happy with it so far.
We will see how it does during track season and in a couple years.
***Edit***
Powell already stated it. Disregard mine lol
Old Mar 23, 2013 | 01:22 PM
zrated89's Avatar
i have had it for 45k miles. Numerous 7k rpm launches on slicks, no slip. even on my turbo 6262 setup still holding strong almost 50k miles later
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
