Hard Shifting
Hard Shifting
My 2009 TC has been increasing hard to shift. It started out as an intermittent thing a couple hundred miles ago, but it was getting so frequent I parked it last week afraid of getting it stuck somewhere (maybe breaking a cable or that it was the transmission).
I've got 64K on it, and it's been driven pretty hard a lot of the time. It is hard to shift 1-2 and 3-4. Last week when it was cold I tried to shift (engine off) through the gears and there wasn't a problem. Then I tried it again with the engine started and the clutch in, still no problem. But like I said it was intermittent.
I'm going to look at it this weekend, I'll pull the console and look at the cable ends there and at the tranny. I don't know if that will tell me much if one of the cables is worn or frayed inside the casing. Maybe just needs adjustment from the cable stretching?
I didn't want to buy new cables and go though the hassle of installation if I didn't need them. And I haven't ruled out the transmission either. I have read all the other posts here and that at least gives me an idea of what to expect. I don't think it's the clutch dragging (only 20k on that) although when it's really cold (below freezing) I have had started the car in first gear with the clutch in and had the car move a little.
Any thought's on this?
like they stated months ago, be easy on the car, just because you have a "stage 3" clutch doesnt mean anything. that trans is gonna be next esp if you dont have a built trans. the K04's are fast spooling turbos and the torque hits instantly. assuming you know what your doing but try not getting into full boost before 3500-4000 rpms.
JesterScott
03-28-2016 10:27 PM
JesterScott
03-14-2016 08:30 PM
