View Poll Results: Which Clutch should I get?
SPEC 3
20.00%
SPEC 3 +
60.00%
SPEC 4
20.00%
Voters: 10. You may not vote on this poll
Help with Choice
Help with Choice
Hey guys, I know I'm going to need a new clutch on my car when I get back from Iraq (not that my stock one is bad by any means), but I will be over-powering it. I'm going to be in the range of 450-470whp when I get back, and need to know what clutch I should be looking at getting.
Also, I don't know what the differences between them. What is the difference between the 3 on the poll? I know the higher the class, the better friction and pressure in the clutch, but what are the ratings of each?
Well, the 2+ is rated 437 tq and I remember the 3 being lower than it was. Looks like at least a 3+ then.
Don't forget to get a ZZP adjustable rod at the same time. the stock clutch rod will bend.
Actually SPEC 3 is 495, SPEC 3+ is 550, and SPEC 4 is 495. So I'll probably get the SPEC 4, as I don't see myself having more than 500tq, plus I like the fact that SPEC 4 is a solid hub. Where can I get ZZP's adjustable rod? is it the same for the SC's?
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
