Here we go again TOB went
Old Aug 17, 2013 | 05:16 PM
  #51
mongorat427's Avatar
Originally Posted by Fastgti69
How does one check a good TOB? James went out on the way here now we gotta swap it out before we swap motors etc. I want to make sure we have a good on before we install it.
From a Guru friend of mine. Quote( Take new tob, and holding it in your hand with slight pressure on the tob, apply lite pressure to the clutch pipe port. It should immediately react and travel out. If it takes a lot of air pressure to move the tob out, its defective. As you apply higher pressure the defective TOB will move with a pop/ but the seal is too hard, and it wont move out with normal bleeding which makes it defective and the beginning of the end.)Unquote It works and you only need about 5 lbs of pressure to make it move. Shouldnt be any binding at all.
Last edited by mongorat427; Aug 17, 2013 at 05:16 PM. Reason: Automerged Doublepost
Old Aug 17, 2013 | 05:45 PM
  #52
bigturbohhr's Avatar
how do u put pressure into the clutch pipe port, just with air blower?
Old Aug 17, 2013 | 06:00 PM
  #53
SalvageBaltSS's Avatar
Originally Posted by mongorat427
Balt back together
nice! Im having a problem with the clutch line block leaking. Well I hope that's what it is, if its my tob, im gonna be pissed, cause then I have to pull it again
Old Aug 18, 2013 | 01:39 AM
  #54
^ they go bad as often as the tobs do lol
Old Aug 18, 2013 | 03:17 AM
  #55
ItalianJoe1's Avatar
FWIW, I've just started to replace that pipe every time, it's only about $9 and they leak too easily. Changing it requires dropping the trans again, so it's very cheap insurance to change it out with the TOB while you are in there, rather than having to do it again.
Old Aug 18, 2013 | 02:48 PM
  #56
uh oh. I hope I can make it work with the pipe I have! I don't want to pull the trans again!!!
Old Aug 18, 2013 | 09:16 PM
  #57
Make sure the end of it is perfect and the little cup seal is properly installed and clean, then clean the block very well and make sure the clip is installed properly before you snap it on. Once that's done, try not to rotate it too much. Used ones are really sensitive compared to new ones, that's why I just like to replace it after having an issue on two cars. Not dropping a trans for free again
Old Aug 18, 2013 | 09:35 PM
  #58
Im going to buy a brandnew clutch block for it. Hope that fix's it . Where do you get yours?
Old Aug 18, 2013 | 11:11 PM
  #59
Dealer, always. I used to order them from my local parts guy, I guess CED would be the best option now. Last two clutch jobs I did were a while ago and I had the customers bring the parts with them so I haven't bought them in a bit. You cannot get the seal by itself, it comes on the pipe, so if you are getting the block and want a new cup seal you will have to buy that 'clutch pipe' also I believe they call it.
Old Aug 19, 2013 | 12:21 AM
  #60
haha ok man! Thanks for the help, it really helped! Mongo sorry for thread jack
Old Aug 19, 2013 | 02:24 AM
  #61
jp1600's Avatar
Shop just did mine to salvage, same damn problem, double labor time.... $$$
Old Aug 19, 2013 | 07:34 AM
  #62
I put all 3 parts in new because their cheap compared to labor
Old Aug 19, 2013 | 07:48 PM
  #63
The block can be changed later with no real issues, and unless it's corroded inside it shouldn't ever give problems. Main issue is people twisting/damaging the pipe when removing or the seal not being perfect, both of which are remedied by replacing the pipe, which requires transmission removal. Spending the extra $10 is always worth it to avoid the risk of re-doing the entire job.
Old Aug 19, 2013 | 08:29 PM
  #64
I got the new pipe so I can jack the new gasket off of it, and the new elbow from Gm. Was like 45 bucks with tax. . Hope that fixes it, and isn't a bad pipe. If so that's gonna suck. I don't want to pull the tranny out again.
Old Aug 20, 2013 | 10:25 AM
  #65
blueLNFftw's Avatar
If your talking about the clutch pipe the trans comes out for that...
Old Aug 20, 2013 | 01:47 PM
  #66
Its a tiny O ring. Might work .
Old Aug 20, 2013 | 02:09 PM
  #67
I know that. I think I need the little gasket/ o-ring. for it, that's why I bought a new one.
Old Aug 20, 2013 | 06:13 PM
  #68
Its bonded to the pipe so be careful
Old Aug 20, 2013 | 08:23 PM
  #69
thanks for letting me know.
Old Aug 20, 2013 | 10:00 PM
  #70
Powell Race Parts's Avatar
hey its not bonded to the pipe fyi. pay attention to the seal lip when u replace it.
see where the clip goes?Name:  DSCN6316.jpg
see the seal? aaarkkk aaarrkkk
Old Aug 20, 2013 | 10:17 PM
  #71
yup I see them. My uncle put on the elbow joint for the clutch ( worked together changing it) due to he knows how to bleed clutchs and I do not. When I showed him the picture of the seal, he said it might be jammed into the elbow . My parts from Gm should be here tomorrow morning . And thanks Powell for the pictures, it sure helps a lot! .
Old Aug 20, 2013 | 10:33 PM
  #72
jp1600's Avatar
Sooooooo, on mine it turned out it wasnt the tob..... Damn mechanic let the nipple in the clutch pipe sit up in the elbow and didnt put it on the end of the clutch pipe..... So i had to tear the whole trans out to find that out..... Thanks mechanics... This is after i pointed it out to him, and he said oh yeah ill get that..... So on my way to get a refund (hopefully) tomorrow
Old Aug 20, 2013 | 10:48 PM
  #73
sometimes the seal gets left behind in the elbow and you put in a new pipe and now two seals. no workie.
turn it over and check pik it out if there is a seal in there.
Old Aug 20, 2013 | 10:51 PM
  #74
jp1600's Avatar
Yeah i know i showed it to him even, told him what to do :l
Old Aug 21, 2013 | 12:02 AM
  #75
For a real mechanic to do that is crazy , but everyone makes mistakes . My uncle and I are back yard mechanics , so little stuff like this you cant get to angry.. You learn something new everyday . Next time I do a tranny, I will make sure EVERYTHING inside, tob,piping, elbow is good. Just so I have a clear head, and not to worried about it.
