Hurst Shifter
Well when I bout mine it did not give me a choice so for my sake I hope they are all gunmetal for now because that is what I want. I am sure in the future they will give a choice do to all the guys that seem to want the polished shifter.
Originally Posted by mcz34man
alrighty I have my hurst shifter installed......this thing is awesome you can definalty tell the reduction in throw, this shifter was a breeze to install only took me about 45 minutes! pictures are in the gallery!!!!! enjoy!
Originally Posted by RL-2005
any hints on how to unhook the shift cable connector once i shift into fourth? I am gonna finish up the install at lunch
BTW...
Already ordered!
Aaron from Turbo Tech told me that they don't have them in stock yet but if you place the order through them they will put your order in and it will get shipped straight to you from hurst.
Originally Posted by 06silverss/sc
Reverse lock out doesnt work and 5th gear is hard to find. fells like the shifter moves over too far and wont go in 5th.
I contacted the Hurst Manager of development about the lockout, he is supposed to get back to me on it.
not worried myself, it is a nice shifter and as long as you dont go all the way right there is no chance of going into R by accident
Mine fells like it keeps hanging up, cant find a happy medium. I also talked to tech department and they said they would get back to me.
Originally Posted by SS_SC_Cobalt
ya hold the shifter use a long screwdriver and pry down evenly by the connector. Keep pressure even and not sharp....
BTW...
Already ordered!
BTW...
Already ordered!
hey man you got yours from that ebay company right and you got this sticker with it?
no lock out problems for me, yes i do agree 5th was a little weird at first but not that bad after all
so you can only put it in reverse by pulling up on the lockout? See if you can go into reverse without lifting it.
yep, i can NOT put it into reverse unless i pull up the lock out........no problems with this shifter!!
so far a lot of guys are able to put it in reverse without using the collar? Have you tried without?
hmmmm....
Well the shifter just has a little edge that sticks out and the shifter mount has another edge so the shifter just barely won't clear unless you pull it up, I can see how over several months of driving the ledge could be worn down enough for the shifter to clear without pulling it up.
