Hurst Shifter
Old Dec 10, 2006 | 06:36 PM
  #151
RBC's Avatar
RBC
just installed mine today. it wasn't very hard but somethings were a pain in the ass. The directions were good to a point, and I figured out some of my own tricks to make life easier. One question that I have, is there any adjustment that can made to the shifter left and right? If I push the shifter all the way to the right it won't go into fifth. You have to bring it back to the left a little bit and slide it in.
Old Dec 10, 2006 | 07:32 PM
  #152
bavoose's Avatar
yeah because if you look at the shift pattern on the shifter its not all the way to the right and up for 5th its a little before it because reverse is all the way to the right and down found that out today when i put mine in.
Old Dec 10, 2006 | 08:27 PM
  #153
BCobaltSS's Avatar
So has anyone done the compare yet now that they have the Hurst in theirs VS the B&M? Where did evyeryone get theirs from? I see that Crate engine is now selling them for $149.99 . Any place cheaper?
Old Dec 10, 2006 | 11:56 PM
  #154
RBC's Avatar
RBC
i got mine at turbo tech. I am not really sure of the price I will have to check.
Old Dec 11, 2006 | 02:02 AM
  #155
alleycat58's Avatar
Where you clip the left cable adjusts where the shifter sits left to right. Hold the shifter in place with your hand and clip the left cable down. The way mine is fifth is where it hits the ridge for reverse lockout, just like on stock.
Old Dec 11, 2006 | 02:17 AM
  #156
RBC's Avatar
RBC
Thanks, I will check it out and see what I can do this week.
Old Dec 12, 2006 | 07:03 PM
  #157
redss05's Avatar
anyone ever think about cutting their hurst and making it shorter? or taking off the whole reverse lockout?
Old Dec 12, 2006 | 07:07 PM
  #158
1gmfanatik's Avatar
Why disconnect the reverse lock-out when it works?? All you have to do is adjust both cables. And why cut a perfectly new shifter?? Waste of money if that's your plan.
Old Dec 13, 2006 | 02:00 AM
  #159
RBC's Avatar
RBC
I think it would be difficult given the design of the shifter as far as cutting. The reverse lock out doesn't really bother me like it does some people. But hey give her a shot.
Old Dec 13, 2006 | 08:34 AM
  #160
gringojoe's Avatar
I'm confused, you ordered a Hurst or a TWM?
Hurst is for 2.0 only, which might explain the problems unless you're trying to alter the Hurst to work on a 2.4 shifter, in which case you're gonna be on your own, don't think anyone's tried to tackle that yet.
I have the Hurst shifter and when I spoke to them they said it would fit on the 2.4l SS. *groan. This is what they said...
Jay: HURST-QUICK STICK SERIES SHIFTER - CNC Machined From Billet Stock For Extra Strength And Reliability, Direct Replacement Shifter With 30% Shorter Throw, More Positive, Precise Shifts, Includes Billet Aluminum Engraved Knob
Jay: Correct?
Joe: Yes
Jay: Yes it will fit..
Gringo
Old Dec 17, 2006 | 09:50 PM
  #161
silverSS's Avatar
will installing this reduce the life of the syncros? thats what i have heard
the last thing i want is to have to take the car in to the dealer and they deny warranty work because i have this installed..im wondering if i get it installed @ the dealer that they wills till warranty it?
Old Dec 25, 2006 | 10:51 AM
  #162
bamfnss's Avatar
Ok, so what steps do I need to take to make the reverse lock out work? I planned on calling Hurst tomorrow.
Old Jan 8, 2007 | 09:27 AM
  #163
KAB's Avatar
KAB
Reverse lockout fix
Adjustment for Reverse Lock-Out (if required)
If shifter engages “reverse” without pulling up on the “lock-out” collar, adjust the shifter cable as follows: A) Place shifter in “neutral”. B) Mark the position of the left side cable where it enters the connector. C) Carefully pry the clip (usually white) out at the bottom to release from the connector and pull up. D) Move the shifter slightly to the right so that the connector is positioned approximately 3/8” further back on the cable from the marked position. E) Push the clip down to lock the cable into the connector. Check to be sure that shifter will not engage reverse unless “lock-out” collar is pulled up. Repeat this procedure if further adjustment is necessary.
Old Jan 14, 2007 | 12:35 PM
  #164
Boosted_SS's Avatar
i just ordered mine along with a Fujita F9 CAI I'm excited to say the least!
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
