HURST SHIFTER Reverse lockout fix
Old Jan 10, 2007 | 09:52 AM
KAB's Avatar
KAB
Reverse lockout fix --------------------------------------------------------------------------------
Adjustment for Reverse Lock-Out (if required)
If shifter engages “reverse” without pulling up on the “lock-out” collar, adjust the shifter cable as follows: A) Place shifter in “neutral”. B) Mark the position of the left side cable where it enters the connector. C) Carefully pry the clip (usually white) out at the bottom to release from the connector and pull up. D) Move the shifter slightly to the right so that the connector is positioned approximately 3/8” further back on the cable from the marked position. E) Push the clip down to lock the cable into the connector. Check to be sure that shifter will not engage reverse unless “lock-out” collar is pulled up. Repeat this procedure if further adjustment is necessary.
Old Feb 5, 2007 | 11:30 AM
CTCOBALTSSS's Avatar
That should help a lot of people, thank you.
Old Feb 5, 2007 | 11:32 AM
Matty's Avatar
A little bored CT ?
biniecki
Oct 25, 2015 02:23 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
