I need a new clutch
Old Jun 24, 2010 | 02:53 PM
bella06's Avatar
I need a new clutch
Hey, I have an 06 SS 2.4 and I need a new clutch because mine is slipping bad, where do I get them and what is a good aftermarket clutch?
Old Jun 24, 2010 | 03:01 PM
scotch89's Avatar
http://www.crateenginedepot.com/stor...ions-C228.aspx
Old Jun 24, 2010 | 04:45 PM
selfinfliction's Avatar
buy the most expensive clutch you can find, that way when you're sitting around with friends, you can brag about having the most expensive clutch you could find!
Old Jun 25, 2010 | 11:34 AM
JANDERSON7757's Avatar
do you guys run a stock clutch? mines pretty much done and I dont wanna pay $500 for a clutch. is it ok to use the OE clutch if your running like 270 HP? and what kind of clutch do you have?
Old Jun 25, 2010 | 12:18 PM
you'd be better off just getting that upgraded clutch from CED. the problem with the stock setup is the pressure plate. it's made from a bottle of weaksauce.
you may be able to get away with just using an LNF pressure plate and the oem clutch disk, i'm pretty sure the dimensions are the same.
Old Jun 25, 2010 | 12:24 PM
Black SS/SC 06's Avatar
I didn't realize those upgraded clutches were that cheap. Looks like I know where I am getting mine from.
Old Jun 25, 2010 | 12:30 PM
yeah for just a bit higher power levels you can't beat it. $250 for a better clutch with a $50 TOB? great deal
Old Jun 28, 2010 | 06:36 PM
I want a better clutch because the stockers, blow! but that like %75 of my paycheck. just wanted to know if anyone else was running stock clutch with mods.
Old Jun 28, 2010 | 06:42 PM
denlou's Avatar
I've been running the stock clutch with minor bolt ons, and a 2.9 pulley for a while now and it doesnt slip at all. It goes to the track a fair bit, so I don't understand what everyones issue is.
Old Jun 28, 2010 | 07:16 PM
D-mac's Avatar
Im not 100% on this but arent the LSJ GM Upgrade clutches our stock LNF Clutches
If so i wouldnt buy that as mine melted
LNF > LSJ
But seriously the LNF issue is the amount of low range Torque
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
