I need a new clutch
you'd be better off just getting that upgraded clutch from CED. the problem with the stock setup is the pressure plate. it's made from a bottle of weaksauce.
you may be able to get away with just using an LNF pressure plate and the oem clutch disk, i'm pretty sure the dimensions are the same.
I've been running the stock clutch with minor bolt ons, and a 2.9 pulley for a while now and it doesnt slip at all. It goes to the track a fair bit, so I don't understand what everyones issue is.
If so i wouldnt buy that as mine melted
But seriously the LNF issue is the amount of low range Torque
