IC pump helpage
IC pump helpage
okay so i have a Ca h/e running with the stock h/e and a option b without a dual pass.
i had a slight problem with rrunning my hose, i ran it in a way that the coolant would not get pushed down because i didnnt no it was gravity fed, and my iat2s were 170 after a 2gear pull and would drop down to 120-130 cruising. from that time i have fixed the hose and it gravity feds properly, my concern is is my pump bad?
how do i no if my pump is working???, i hear it on and when i open the cap for the option b i get bubbles. is it normal for bubbles to come up??? iv had this installed for 4 weeks now so i would imagine there is no air bubbles.
the coolant in it doesnt get hot but its just gets warm.
well the hose from the tank to the T fitting is going down then lil bit upwards, but the tank sits higher than the T fitting where the hose connects, would i have a air pocket where the hose goes up a little?, and the bubbles would b like lil ones every now and then
roth
Sep 26, 2015 12:16 PM
