Installing junker LSD tranny, suggestions?
Old Aug 5, 2008 | 10:49 PM
Dainslaif's Avatar
So I'm planning on getting an LSD transmission from a wreck shop in another state. It has 17k miles on it, the guy at the shop said it worked fine before it got wrecked, and the car was wrecked from a rollover (so in theory it should be mechanically sound). Since I am pulling the trans, am taking the opportunity to swap the clutch. I have a few questions;
I'm planning on taking everything to a trans shop to be installed, so I'll ask them to look the transmission over, but is there anything I should look for on the outside before I have them install it, only to find out it was busted in some noticeable way? I don't need the speed sensor (04 Redline), but is there anything else I can examine on the outside?
Is it worth the money to get new flywheel bolts? I have only found them at CED for $50, which seems high, but if reused bolts have any history of failing I'll just get new ones. Also, does anyone have a part number?
I planned to get the trans fluid from a dealer, but I've heard rumors of an additive for LSD equipped transmissions. Is this right? Since I'm getting the fluid from a dealer I can just ask, but if I have a part # that'd make it easier on me because most dealers are less than helpful.
That's all I can think of for now. Thanks for any help.
Old Aug 5, 2008 | 11:25 PM
Smarty Art's Avatar
I reused my flywheel bolts and everything is still fine.
Old Aug 6, 2008 | 12:40 PM
SymbioteLT's Avatar
dont forget to replace the throwout bearing too
Old Aug 6, 2008 | 03:35 PM
Smarty Art's Avatar
Yeah, its cheap if u by the part online(80-90$). The dealer will charge you 120-130$. You could change it yourself to save some money. It's just 3 torx bolts and the line in. Take 5 minutes to change.
Old Aug 6, 2008 | 09:02 PM
Dainslaif's Avatar
Yeah, I had planned to order the bolts and ToB from GMPD and swap the bearing before I even take the trans to the shop.
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
