issue please help
Old Mar 6, 2011 | 01:50 PM
DEZZIE41's Avatar
Exclamation issue please help
so just put in my ottp stage 2 mounts, started up the car and shes vibrating like there loose but there not i put the spacers on the inside of the brackets, is she suppose ot vibrate like this info please
Old Mar 6, 2011 | 01:53 PM
CanadianCobalt's Avatar
My OTTP mounts vibrated a bit until they broke in, now either it doesn't do it or I just don't notice it at all. That's the reality of them.
Did you put them to torque spec? Also the two spacers go on either side of the mount, not sure what you mean by on the inside.
Also did you go for a drive with your engine mount bolts back 1/4 turn and the tranny mounts not uber tight to settle it?
Joel
Old Mar 6, 2011 | 01:54 PM
DEZZIE41's Avatar
like u got bracket for the mount so it should go mount bolt in spacer on each side of rubber?
what are the torque sepecs
Old Mar 6, 2011 | 01:57 PM
Do_WorkSS's Avatar
anytime you switch to a "solid" type mount, there will always be vibration. When I put my TTR mounts in, they were vibin pretty hard for about the first 1K...then after that they were the shiznit!!!
Originally Posted by Pyros777 from the "Various Torque Spec's" Thread
Transmission Mount to Transmission Bolts
89 Nˇm
66 lb ft
Transmission Mount (Rear) to Frame Bolts
60 Nˇm
44 lb ft
Transmission Mount Through Bolts
100 Nˇm
74 lb ft
Yea, thats where the spacers go.
Joel
srt-10's Avatar
1. the mounts will vibrate alot when u first install them, once they work in they will still vibrate but not as much.
2. Did u torque them right away? You are suppose to leave the bolts abit loose, go for a drive with light throttle and under 3000rpm. This gives the mounts/tranny/engine time to settle in. Then once done torque them to specs.
3. cant remember the specs, think they are around 60ft lbs...not sure though.
Old Mar 6, 2011 | 01:58 PM
DEZZIE41's Avatar
ok so this is normal i knew i pout em on right but was like holly **** the vibss so ignor it and it should sellte out o and puls the car is lowered 2 inches
no i did not i just put them in and then as tight as possible
Old Mar 6, 2011 | 02:00 PM
srt-10's Avatar
Back off the tightness and leave 3 threads showing. Go for a 5min drive around the block with light throttle/shifting to let everything settle in.
Old Mar 6, 2011 | 02:01 PM
DEZZIE41's Avatar
damm it so i got to take it apart again like right now?
Do_WorkSS's Avatar
I just set my impact gun to high and held the trigger for three seconds.
Old Mar 6, 2011 | 05:23 PM
srt-10's Avatar
i would do it, yes. Its unlikely, but your engine/tranny could have shifted when you swapped them, even 1/4 of a inch or smaller. But when theres any movement, it could cause issues. Once again, untightening the bolts will let everything settle, then re-tighten them to the specs. It will also help with the vibs.
Once again, it could or couldnt cause issues. But would you rather take the extra procaution and go by what should have been suggested in your instructions (because it was on mine) or would u rather take the risk and something seriously going wrong with your engine/tranny.
funny story about a person i met that did that...
Me, my gf and my buddies were at a parking lot with our bikes shooting the ****. Down the road all we heard was this weird screetching sound but couldnt see anything...then all of a sudden comes bouncing a wheel. We ran over to this kid that had a riced out sunfire and aftermarket rims. His wheel came flying off and he skidded about 50 meters on his right front brake rotor, in the process tearing his front bumper and other things apart.
We asked him what the hell happend and he said he has no idea, him and his buddies just put new tires on the rims and he just left the shop a few mins ago. we asked him if he torqued the lugs to specs, he said yes. So we looked around and tried to find out why it happend, we asked him again "are you sure you torqued them to specs" he said "yes im not a retard" we then asked what were the specs, he said "we dont know, we just used the impact gun and went until it wouldnt go any tighter"
Moral of the store, dont be a lazy ass, find the specs, do it right...
Old Mar 6, 2011 | 08:38 PM
Do_WorkSS's Avatar
lol...that hurt dude. however i'm not that dumb, i work at a tire store and i know everything that there is to know about torque
Old Mar 6, 2011 | 08:47 PM
northvibe's Avatar
did you loosen the 3 bolts on the SIDE engine mount? Mine did the same thing and powell told me to loosen those let the engine settle then re tighten them to spec and it was much better.
Old Mar 7, 2011 | 09:35 PM
DEZZIE41's Avatar
i put about 600kms on er today and the mounts are still tight as **** what gives
are the vibs every going to mellow out
Old Mar 8, 2011 | 12:18 AM
Do_WorkSS's Avatar
I dont know what 600kms is in miles, but it does take some time for the things to break in.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
