LNF Cruise Control Function with MU3
Old Aug 21, 2014 | 12:12 AM
SaturnLNF's Avatar
Does the cruise control still function if you were using a 08-10 LNF ECM and BCM and an F35 transmission with the 4.05 final drive ratio?
My old Saturn does not have functional cruise control when you change gear ratio because the clutch slip is calculated by RPM-speed ratio. The Cobalt has a clutch pedal position sensor to disengage the cruise, so a different transmission shouldn't affect it, right?
Old Sep 2, 2014 | 12:26 PM
Mendomar06's Avatar
Yes it should still work, I'm running a 2010 LNF trans in my 06 and CC works perfectly fine
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
