lsd install ?s
Old Mar 15, 2010 | 12:42 PM
edmbaltss's Avatar
Canada lsd install ?s
i am wondering if there are any aftermarket lsd kits for a 07 ss/sc ?my car didnt come with it from the factory. how hard would it be to install? would it be easyer to jsut find a tranny with one? would GM sell just the lsd?
Old Mar 15, 2010 | 03:56 PM
Blue_Balt's Avatar
You're better off trying to find an F35 with the lsd already on it.
Old Mar 15, 2010 | 03:59 PM
alleycat58's Avatar
x2 find a tranny with one already installed. Easier AND cheaper.
And FWIW, GM doesn't sell the LSD, it's a Quiafe unit and it goes for ~$1000 now a days I believe.
Last edited by alleycat58; Mar 15, 2010 at 03:59 PM. Reason: Automerged Doublepost
Old Mar 16, 2010 | 12:06 AM
red06SC's Avatar
will you be autox-ing this car or road coursing it?
if not, you're wasting your money
Old Mar 16, 2010 | 12:09 AM
thedude411's Avatar
lsd is nice for winter driving too.
Old Mar 16, 2010 | 12:17 AM
red06SC's Avatar
true
completely overlooked the whole canada thing
Old Mar 16, 2010 | 02:41 AM
edmbaltss's Avatar
Canada
it would help with drag racing before my clutch went i couldnt get it to hook in first or second it gets a little old real quick and it might help with torque steer which i have bad
Old Mar 16, 2010 | 09:47 AM
alleycat58's Avatar
It doesn't help with torque steer at all........and it won't help much at the drag strip since it's possible to spin both front tires in a non-LSD car IF you're on level pavement and going straight. If that's all you want it for, you're wasting your money.
Old Mar 16, 2010 | 10:27 AM
Blue_Balt's Avatar
Wouldn't help with that. All an LSD does is balances the difference in spinning between the outside and inside wheels during a turn.
Old Mar 16, 2010 | 10:54 AM
edmbaltss's Avatar
Canada
how would it not help with torque steer it would stop the tires fighting with eachother why do you think they would put it in from factory cars and it would help at the drag cause both tires would have traction why do you think dragsters have locked diffs so both tires have traction not just one
Old Mar 16, 2010 | 11:03 AM
alleycat58's Avatar
1) Torque steer is a whole different beast altogether and has NOTHING to do with the differential and EVERYTHING to do with having power in the FWD car. I've driven numerous Cobalts with and without LSD and it doesn't make a bit of difference in the amount of torque steer.
2) If you're not getting traction to both wheels at the strip, you need driver mod, not LSD. When taking off *in a straight line* both tires have an equal chance at getting traction. It's definitely possible to lay down two strips of rubber without the aid of an LSD. The LSD helps when turning, not so much in a straight line. It is NOT the same thing as a locking differential. You're not going to see enough benefit from an LSD to justify the cost and labor of buying and installing it.
Old Mar 16, 2010 | 11:15 AM
edmbaltss's Avatar
lsd does not help with turning it will become disconected around a corner it will help when you come out of a corner thats it i have had lsd in many vehicles mostly jeeps and it make a world of difference
Old Mar 16, 2010 | 11:20 AM
alleycat58's Avatar
Exactly. It's useful when you're trying to power through/out of a corner.
It's your money, do what you want with it.
Old Mar 16, 2010 | 11:22 AM
edmbaltss's Avatar
i just wanted to know if it would be easyr/cheaper to install the lsd or change out the tranny
Old Mar 16, 2010 | 11:29 AM
alleycat58's Avatar
Bottom line: Tranny. You're probably looking at upwards of $3k or more in parts and labor to have the diff installed.
Tranny you can probably get from a junkyard for < $1000 and install it yourself if you have the tools.
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
justinchinn
Oct 2, 2015 12:18 PM
importkiller
Sep 30, 2015 07:18 PM
