LSD vs Non-LSD?
The only place it makes a real difference is on the track, or inclement road conditions. If you're not going to be a regular racer then it's no where near worth it. It's $1000 just for the part, then the labor to have somebody drop your tranny and install it.
I am a regular racer and haven't convinced myself to spend that kind of money.
There are cheaper versions that are not the quaife but it's said that they don't last unless you replace some bearings/washers or something then they're supposed to be good to go.
There's a guy on the forum that talks about what you have to do to the cheaper ones to make them good. Do enough searching and you'll find where he posts about it.
I'm buying an Exedy today from ALL ECOTEC and still need the LSD. Planning on running at least two series this year, maybe more. The LSD sure would help.
I am hung up on this as well. I am building my 2.2 to make about 350hp at the crank and the rest of the car. I want it to be fun to drive and I want it to be a mustang killer. It will be my daily driver and that damn LSD is expensive. my build is already pricey, I just wonder if it will be worth it to install that LSD. FWD and over 300hp at the wheels, I probably dont have a choice.
LSD isnt that effective in FWD. Well for what I assume you are talking about (1/4 mile like acceleration). In theory its suppose to make both tires spin at the same time, giving greater traction, in RWD applications this is great, because you can go 100% lock where neither tire can turn at all without the other turning, giving greatly inproved performance. In FWD applications though, due to the need to actually steer the car, they cannot have a very affective locker. Reasons being if you had a locker in a front axle of anything, when you turn the inner and outer tire turn at different speeds, which makes it very hard to sterr if you disable their ability to independently turn.
Im not familiar with the G85 and what % slip it is. However what you really want is a locker that locks up 100% when your doing the 1/4 mile and something like 20% on the road (again not familiar with the G85 %)
Ok so summery, its always good to have it, if you dont you really arnt missing much unless you do a road course. Alot of debate on the LSD vs non LSD on this forum, I dont believe its worth the 1000 bucks, try other traction mods.
My truck is 100% locked, it did wonders for traction, however both tires still spin together at times.
For 1000 bucks Id get mounts and tires.
The lsd is a big help in the road course for exiting turns and such, but in a straight line, either trans should have no issue putting down the power.
Maybe you should read the dates of threads before posting nonsense.
Back in 08' people on this site did not understand lsd vs non lsd trans.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
importkiller
Sep 30, 2015 07:18 PM
