Lucas Stabilizer in Transmission
Hey guys, so a buddy of mine let me drive his 2011 lancer w 60k miles and it was grinding terribly into 3rd no matter what speed. Even when coasting 5 to 10 mph it would not engage 3rd without grinding so loud that everyone in the parking lot could hear it.
Long story short he was about to have the tranny rebuilt when I told him to change his tranny fluid.
He put a pint of lucas transmission fix and a little mobil 1 75w-90 in it and now it's not even noticeable. . . .
So many have called bs on this but I swear you would never know anything was wrong with that tranny now.
Now i'm getting the hard shifting with the valvoline 70w-90 and I'm trying to decide between Royal and the lucas stabilizer/ or trans fix
Is it worth it
Is it worth it
Yea ik ik GM blah blah blah I'm probably going with royal purple anyway. . . .
Really though. It may not have fixed his transmission but it sure did quiet it down lol
Sometimes I get stuck at lights because my tranny won't go into 1st
edit: happens at random, in random gears too, thinking maybe I should change the clutch fluid? it's like shifting through rocks
Yea ik ik GM blah blah blah I'm probably going with royal purple anyway. . . . Really though. It may not have fixed his transmission but it sure did quiet it down lol Sometimes I get stuck at lights because my tranny won't go into 1st edit: happens at random, in random gears too, thinking maybe I should change the clutch fluid? it's like shifting through rocks
Mine sometimes wont go into 1st either and lots of others have experienced this too. Just let go of the clutch and press down again. Should slide right in
Yep i went the royal purple route once..... It was ok through the summer and as soon as it got below 35 it was a bitch to shift. I put lnf fluid in it and its like a new transmission. Just do it right is my 2 cents worth. Cost more money in the long run.
as far as transmission additives and fluid type, in our transmissions run the gm stuff only. many have tried all sorts of different fluids, the results are, the gm stuff is best. adding lucas oil stabalizer is a bad idea as it will just make the fluid thicker. oil viscosity in a manual transmission is a 2 edged sword. when the oil is too thick it cant be pushed from behind the syncros during a shift, causing the syncro to slip, and ultimately causes the grind or "munch" during a shift. if the oil it too thin it will not lubricate the bearings and gears correctly and could ultimately lead to a failure. todays manual transmissions have evolved to the point were they are no longer designed for a universal fluid, to get optimum driveabiity they design the transmission to use a very specific fluid, often times a fluid is designed for only one or 2 models of transmissions.
Our cars use ATF to begin with. You can use GM, however I've been using Amsoil ATF for over 25,000 now and you wouldn't know the difference, and it still shifts as it was fresh. It meets or exceeds Dexron 3 requirements.As for additives, I wouldn't do it as the additive could compromise or alter the fluid function.
All i have to say if the manufacturer already put a fluid that works why change it up. Unless your a engineer and know everything i wouldnt risk it, simple as that. They create that fluid for a reason as sometimes different detergents are used also the way some fluid react to metals or plastic is different so more than likely you will end up braking something.
I had my tranny grind soon after (within 2000km) of GM replacing my fluid at 75,000km. Not sure if they used LSJ fluid or what. But it was weird that I take it in for preventative maintenance and than the tranny goes right after. Replaced with a brand new unit for free under warranty though, can't complain too much.
its not a total gimmick. ive worked on a number of different blown alcohol dragsters and funny cars and we use lucas products with great success. we often use the engine oil stabilizer as a pre lube for valve train components instead of just oil, the lucas sticks to the rocker arms much better and gives better prelube for the initial fire up. we also use 1-2 quarts of the engine oil stabilizer (depends if its a dry sump oiling system or not) in the oil. we have noticed higher oil pressure at stage rpm and higher and more stable oil pressure after the finish line. we also notice the alcohol doesnt mix with the oil quite as easy, as a result we can get an extra pass out of the same oil (typically 3 passes instead of 2. important when you have a dry sump system with 20-24 quart capacity). as far as a street car, cant really comment.
Ok you guys have convinced me. I'll order the GM fluid just to be safe. jeez its hard to get ahold of that stuff
Think having valvoline full synthetic limited slip in there for a few k miles hurt anything? will be a week or so before i have the gm stuff and time to change it
btw i have 10w-40 motor oil in my 71 c10 4 speed its borg warner T10
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
