Motor mounts/transmission mounts
I've had my 2006 LS w/ 5 speed for about a month now and it seems like the mounts are either pretty shot or maybe they are always like that. It seems as if there is a lot of movement from say when you take your foot off the throttle and put it back on, as well as downshifting, it seems to jerk quite a bit. The motor seems like it has a lot of "play". It just doesn't seem to be a very smooth car at all, I have to baby it so much when driving so i don't get jerked around all the time. Is this a common thing for these cars?
ottp has actual mount replacements, if you're looking for a much less expensive alternative (also doesn't work as well) get the bushings from turbo tech. they still help out a good amount. also turbo tech has the top mount which is great.
We carry the upper engine mount and tranny bushings for the 2.2/2.4L @ www.TurboTechRacing.com
The OTT tranny mounts only fit the F35 tranny (2.0L), as the 2.2/2.4L mounts are different.
ThoR294
10-04-2015 08:44 PM
n20saturn
09-30-2015 12:26 AM
