need help on dot4 fluid choice?
Old Dec 13, 2012 | 06:51 AM
Powell Race Parts's Avatar
You just bleed through. the clutch the nipple is beside the oil cooler, 9 mm wrench. The brakes start at the rear in an X cross - rr /lf/ lr /rf. the nipples are 10 and 11 mm wrench on a turbo. With the brembos start inside nipple and then outside. Put bleed hose on nipple then have your friend get in and pump/open nipple/close nipple/release and pump again. etc. Clutch is similar, just dont stroke the pedal quickly.
when the fluid comes out of the bleed hose clear and no bubbles you are done... good luck, good buy on the Wilwood...
Old Dec 13, 2012 | 10:33 PM
09slowbaltSS's Avatar
thanks i hope i have this done and ready by next weekend, thats if i get my YYZ v2 by then... =-)
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 29, 2015 11:07 PM
jas09ss
Sep 26, 2015 01:06 PM
Sean Cummings
Sep 11, 2015 09:35 PM
ATOMbomb
Sep 11, 2015 10:48 AM
