need help on dot4 fluid choice?
You just bleed through. the clutch the nipple is beside the oil cooler, 9 mm wrench. The brakes start at the rear in an X cross - rr /lf/ lr /rf. the nipples are 10 and 11 mm wrench on a turbo. With the brembos start inside nipple and then outside. Put bleed hose on nipple then have your friend get in and pump/open nipple/close nipple/release and pump again. etc. Clutch is similar, just dont stroke the pedal quickly.
when the fluid comes out of the bleed hose clear and no bubbles you are done... good luck, good buy on the Wilwood...
