Need a new clutch!!!
Old Oct 19, 2008 | 10:02 PM
ikeryder13's Avatar
I need a new clutch and i dont know what brand to get... I think i am gonna get a Spec Stage 2+ but i know it doesnt come with the flywheel....I need some advice
my clutch is starting to slip very bad
anyone who has this how do u like it?
Last edited by ikeryder13; Oct 19, 2008 at 10:02 PM. Reason: Automerged Doublepost
Old Oct 19, 2008 | 10:05 PM
slowswap's Avatar
A clutch will not come with a flywheel unless it's a twin disk or triple disk. In the 240 world, spec is not a good name at all. Everyone I know loves ACT.
Old Oct 19, 2008 | 10:06 PM
ikeryder13's Avatar
really? is that true?
Old Oct 19, 2008 | 10:10 PM
theneelster's Avatar
Hehe...classy.
Centerforce dfx and exedy hyper SINGLE come with flywheels. Neither are multiple disks. ACT's clutch isn't out yet. Do you own this car?
Old Oct 19, 2008 | 10:11 PM
ikeryder13's Avatar
can i use a spec with a oem flywheel?
Old Oct 19, 2008 | 10:15 PM
it depends, they make ones that work with the factory flywheel but you should probably remachine it prior. they also make kits that only work with the spec/fidanza flywheel.
Old Oct 19, 2008 | 10:18 PM
cblt12's Avatar
i have a spec 2+ that i bought a while back in a group buy because i heard of all the problems people had w/ their clutches. well mine seems to be fine after 60k+ miles of abuse so i dont think im gonna use it. so if you want it pm me i will give you a deal.
Old Oct 19, 2008 | 10:19 PM
ikeryder13's Avatar
well ****! lol any advice on a brand to use
how much jerrod?
Last edited by ikeryder13; Oct 19, 2008 at 10:19 PM. Reason: Automerged Doublepost
Old Oct 19, 2008 | 10:25 PM
how much jerrod?
If you don't plan on going over 300-350 I'd say just get the exedy oem replacement, it's like 200 bucks rated to 350ish...if you want better performance/acceleration, probably exedy or centerforce setup (a tad cheaper).
Old Oct 19, 2008 | 10:27 PM
ikeryder13's Avatar
well i have a stage 2 kit now and i plan on getting atleast my 2.9 pully installed and tuned so i am gonna need a better kit then oem replacement
Old Oct 19, 2008 | 10:46 PM
cblt12's Avatar
400.
Old Oct 19, 2008 | 10:49 PM
ikeryder13's Avatar
ooooo did u get a flywheel?
Old Oct 19, 2008 | 10:55 PM
Jeremy360's Avatar
TurboTech's got a good selection. I haven't seen a Spec yet, but I've talked to Exedy Hyper and Centerforce owners, neither had any complaints.
I was looking at http://www.turbotechracing.com/produ...idproduct=5150 myself, but I've heard mixed things about lightened flywheels.
Old Oct 19, 2008 | 10:59 PM
cblt12's Avatar
nope just the clutch... it was 5 in the group buy
Old Oct 20, 2008 | 01:06 AM
Sharkey's Avatar
spec + series clutches are good, lots of people love them. the spec stage 2 and 3 have had issues, the 2+ and 3+ is what to go with.
Old Oct 20, 2008 | 01:20 AM
stryder's Avatar
well eric it doesn't sound like you have plans on going with big power, go getting a exedy oem replacement would be good too. Or you could see how much a LNF clutch is they are rated higher and might be a little cheaper than the rest. a lighter flywheel just means quicker revs.
Old Oct 20, 2008 | 01:35 AM
Lnf clutches fit the lsj? What choo talkin bout willis?!?
Old Oct 20, 2008 | 01:42 AM
ikeryder13's Avatar
well luke i was gonna try to eventually put down around 300hp... i dont plan on doing a full engine build
Old Oct 20, 2008 | 01:04 PM
stryder's Avatar
Huh?? and yeah it fits why wouldn't it, they didn't change the bolt pattern or anything.
Ok well either of the two i mentioned would work great for you. no reason to go overboard is there? Although if it were me i would do a spec plus lol
Old Oct 20, 2008 | 01:06 PM
REIGN SS's Avatar
Original Hayden Fanatic
Moved to Drivetrain
https://www.cobaltss.net/forums/general-cobalt-68/read-post-correct-section-read-read-now-109153/
Old Oct 20, 2008 | 01:10 PM
Steven Flit's Avatar
You fried your stocker already?!
how in the world?
Old Oct 20, 2008 | 01:15 PM
ColeJJones's Avatar
Bannned
i would get the oem exedy. unless your planning to up your hp. i got the spec 3+ and their lightweight flywheel.... i dont think you need to spend 1200 on a clutch/flywheel. use your stocker with clutch.
how in the world?
easy to fry a stock clutch.
Last edited by ColeJJones; Oct 20, 2008 at 01:15 PM. Reason: Automerged Doublepost
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
