need new ic pump
Old Jun 3, 2009 | 08:00 PM
persiani's Avatar
need new ic pump
what ic pump can i get??? people say i can use the ford ones but theres so many on ebay can someone give me a part number or show me which one to get??
Old Jun 3, 2009 | 08:17 PM
rhanes216213's Avatar
http://www.siliconeintakes.com/produ...oducts_id=1001
Check this one out. This is the one that I replaced my broken stock one with.
Old Jun 3, 2009 | 08:28 PM
all4glh's Avatar
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
Old Jun 4, 2009 | 12:02 AM
persiani's Avatar
do any of these come with fittings? and i heard our pump is the same as ford so if i get the ford one wouldnt it go bad very fast too????,rhanes216213 how long you been running your pump and is it good?? better than stock?
Old Jun 4, 2009 | 12:04 AM
G85 SS's Avatar
click link in my sig. Go to cobalt and then cooling mods. $100 for it.
Old Jun 4, 2009 | 12:05 AM
hatrickstu's Avatar
ott sells them as well
Old Jun 4, 2009 | 12:06 AM
persiani's Avatar
why get it from ottp when the one on ebay is cheaper??
stu from the video i sent, you think i shud get a new pump?? you saw how i was running things, was that right??
Old Jun 4, 2009 | 12:08 AM
hatrickstu's Avatar
if your pump is running, then no. i just think you have air in the system somewhere. i couldnt see exactly what you were doing, but i do think its air
Old Jun 4, 2009 | 12:11 AM
persiani's Avatar
would the air be somewhere in the h/e or btw the tank and T fitting??, tmro im going to log my car to see my iat2s, but as long as my pump is on i shouldnt replace it?
Old Jun 4, 2009 | 12:18 AM
hatrickstu's Avatar
if your pump is pumping there is no need to replace. the hardest part is tracing it down. you can do this by disconnected various parts along the trail and seeing if its pumping out properly.
Old Jun 4, 2009 | 12:25 AM
persiani's Avatar
by various parts where do you think i should unplug to see the flow? i looked at the T fitting that goes into the pump line and it pumps coolant.
Old Jun 4, 2009 | 12:35 AM
hatrickstu's Avatar
just work your way down the system. if you have good flow at each connection then you are good, but i bet you dont.
DarrenGC
Dec 24, 2021 01:55 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
