New clutch bleed procedure
Old Nov 9, 2006 | 12:49 PM
truray4's Avatar
1. Verify that all the lines and fittings are dry and secure.
2. Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
3. 0Remove the reservoir cap.
4. Fill the reservoir to the proper level with the required fluid.
5. Attach the J 43485 (Adapter) to the J 35555 (Mity Vac), or equivalent. (rubber plug to seal onto reservoir)
Important: Brake fluid will deteriorate the rubber on J 43485. Use a clean shop cloth to wipe away the fluid after each use.
6 Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
7 Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter.
8 Refill the reservoir to the proper level.
9 Repeat Steps 6 and 7.
If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
Caution: The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational. Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see if the transmission will shift easily into gear.
Pump the clutch pedal until firm (to refill actuator cylinder).
Add additional fluid if needed.
Test drive vehicle to ensure proper operation
Maybe this will help with some of the clutch issues.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
